so your saying put a piece of timber either side in the vice so its not touching the metal vice, or by soft do you mean wrap it in a cloth then wack that straight in the vice and tighten up?? still have to buy another set of rear pads though....i guess that's not as much as an upgrade.
  • 4 weeks later...
Just wanted to give a big thanks for the information, I went to a few Sprint auto parts who just assumed mine was a 4wd....luckily I didn't buy anything, Repco weren't much help either but autobahn had some for me, does it really matter what brand we're using though?
  • 3 weeks later...
Very neat on clearance there, but I' think you'll be impressed with the improvement!
Yip very happy with it. Calipers getting painted this weekend and rotors are getting skimmed this coming week to remove rust. Decided to go
for new set of wheels because Im not comfortable with wheels spacers. Suspension height will remain standard, as our roads still badly damaged from the quake 2 yrs ago! Cant wait next weekend to bolt it all together now :yes:
Have you thought about getting them to slot the rotors while they're there? Normally costs $50ish per rotor, if your rotors have plenty of meat it is a worthwhile exercise.
I am fitting 32gtr to my s1 just got to get motivated lol plus still waiting on some cash to come in to grab 33gtst rears plus giving my rims a face lift
LOL, I'm in exactly the same boat. I have the R32 GTR front calipers, need to get a matching set of rears. If I can afford it when I do it, I think I'll also stump up for a new set of slotted rotors all around too.
I've been slack and haven't gotten around to upgrading my brakes (F&R R34 GT-T Rotors and Calipers). I cracked open the box since it's been sitting in the shed for about 2 months and looked at the lines I got with them...
This is one of the braded lines I got with it (good thing I saw that they are ADR Approved)
the other braided line is exactly the same
The rears are the stock R34 lines
As you can tell from the last photo it appears that it has been cut from the hard line I think (all the lines have been cut at that point)
Do you think these will work on a S2 Stagea and will the stock R34 rear lines work or will the standard Stagea's one work?? Is there anything extra I need to be aware of??
post-94823-0-07649600-1361007761_thumb.jpgWoohoo got my r34 calipers and rotors fitted on finally. As per some members described, the banjo fittings of the stagea wont screw in properly inside the r34 calipers and suggestions is to remove the olives inside the caliper. We didnt ended up doing this. We drilled the banjo fitting ENDS to TAPER and screw it in nicely(see pic). Also ended up not cutting the dust shields or grinding the steering knuckles, instead fitted a 3mm SLIP-ON spacers between the hub and the rotors which gave us a nice gap in between, washers with the same thickness was used to spaced the calipers and between the mounting lugs. Took it for a test drive and overall braking performance is now way better than the standard single pot calipers.post-94823-0-03811900-1361008584_thumb.jpgpost-94823-0-51631000-1361008614_thumb.jpgpost-94823-0-41298100-1361008658_thumb.jpg
  • 1 month later...
ok, so i should buy the nismo ones to suit my car then? i have the compete R34GTT brake line set-up from caliper to chassis connection, will i just use the last bit of the GTT line that goes to the caliper and screw that into the nismo braided lines to suit stagea?
Nick
While I would normally recommend Nismo gear, remember their brake lines are not ADR approved.
Have you tried Maltech? Expensive but great quality.
There will be something cheap around that fits, what has everyone else done?
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
