I don't it will. I had to go +30 to clear my r34gtt brakes and I just cleared it by 5mm. Its all to do with offset of the wheel.
No, it's not.
You can have a low offset wheel with rubbish clearance due to the spoke design. 2 or 3 piece rims generally state a J type disc reference. While lower offset wheels are more likely to clear, it is not a guarantee.
Try to look at the rims on a r33 or 34.
I was looking at these but they only come in +40
http://www.ebay.com.au/itm/19-inch-wheels-rims-PETROL-VENGENCE-5-114-3-19x9-5-FORD-JEEP-MERC-MAZDA-AUDI-/321094544789?pt=AU_Car_Parts_Accessories&hash=item4ac2b9ed95&_uhb=1
My only clearance issue will the the fronts with my r32 gtr brakes I will b e putting on as ill be keeping the rears as standard for now. At worst just decent pads and slotted rotors.
Edited by joshm35
Having a guess by the look at the spokes and the offset, those have no chance of clearing.
Are your brakes on the car yet? If not, you can take them and place them on the backs of wheels ou like to see if they clear.
Varrstoen do some bbs knock offs too, 19x9.5 +22
These are the others I was looking at and I can get them in +25's
http://www.ebay.com.au/itm/19-koya-inox-aston-bmw-audi-merc-holden-ford-euro-5-stud-stainless-lip-/320898242961?pt=AU_Car_Parts_Accessories&hash=item4ab7069991&_uhb=1
No I haven't got the r32 brakes on yet. In transit.
Edited by joshm35
This has probably been covered.. but hey, worth the info..
I wanted a bigger set of brakes on my S1 M35, but without the big $$ price tag.. I need to tow my race car. ( under 1200kgs).
I found the 14mm caliper bolts hard to get a set of 4 spots for. I rang around a few wreckers & found that the R34 GTT calipers had the same bolt size.
The only mod i needed to do, was to remove the existing backing plate. The R34 GTT kit , bolted straight on. Even the GTT brake hoses fitted up.
Great easy mod for $350. I fitted hawk pads from http://www.vsport.com.au/ .. Been to Phillip Island & back with ease..
Hope this helps..
Was that $350 all up less the pads? Or did you buy new discs as well...that sounds super cheap. Any of you guys know a good wrecker to get the r34gtt setup from in Sydney? And also any idea if it would fit under stock Axis 18s? Cheers!
  • 4 weeks later...
Hey Guys,
Firstly, I want to apologize if this has been covered, I've read nearly every single page of this thread and I'm still scratching my head..
A friend of mine rolled his 32 GTR recently. I own a 98 S2 C34 and I wanted to swap the rotors and calipers over for the GTR set up. Does anyone foresee any issues with this? Will I need to get custom brake lines made up for the new Rotors, or should it all interchange relatively simply?
Again, sorry if this has been covered, I wouldn't be posting if I wasn't desperate for an answer.
Thanks in Advance :)
You'd just need spacers made up to go around the bolts
the 32r bolts will have a 12mm diameter, but the c34 hubs have 14mm holes
and maybe trim the backing shield on the rear brakes (no spacers needed there tho) tin snips work well
one of the m35 guys does them, but i've had too many beers to remember exactly who (maybe daleo or jetwreck)
Edited by pipster11
Hey guys need some info... I have recently changed the brake pads in my s2 c34 to the bendix ct pad, since then I have a grinding sound and feel coming from the front brakes at low speeds as well as a squeal like having low pads. I don't really feel it when the brakes are cold but after 15min or so of driving it all starts. Have pulled off the wheels and check the rotors and they are still smooth??????
A couple of things - first have you put a chamfer on the leading edge of the pad? Rubbing it on a sheet of sandpaper e.g. will do.
Also have you replaced the backing plates and applied some copperslip or other anti-squeal compound?
Cheers Tom, much appreciated mate!
What about the lines? Are they interchangeable between the C34 and 32GTR set up?
You can use either, running the stagea lines means you will have to pull the "olive" out of the caliper (its the thing at the bottom of the bolt hole)
lip on the rotor?
did you bed them in? (5-10 really hard stops from 100km/h to 50, then cruise at constant speed for 5 mins, using no brakes during that time)
Scotty makes the spacers for the bolts.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
