pfft!
my front rims clear the calipers by 1-2mm :(
was looking at a set of 33 GTR brembo's.. but i dont want to change my rims, and id prefer not to use spacers..
guess kylie doesnt get my GTS-T calipers :)
what rotors are they brad, DBA5000?
also, did you need to do anything with the master cylinder upgrading the brakes?
pfft!
yer dba5000 330mm and master cylinder is stock ;)
  • 4 weeks later...
I just fitted a set of front and rear R34 GTT disks and calipers
I also fitted the R34 GTT booster and master, fitted with no problems in a series 2
The booster has a different part number to the Stagea, so I assume they are different inside. They look the same on outside
Can you please post some pics of your install darren? I am planning on upgrading my S1 brakes to 33 gtst calipers soon but what im wondering is will i definately need to upgrade my master cylinder to gtst as well?
  • 5 weeks later...
Hey,
While I'm still a stocker, thought you might like to know I got a set of front pads today. Our local, Mt Tamborine
Spare Parts supplier got me a set. Like SK suggested way back, I got Lucas/TRW with the Australian Reference DB1398.
Incidently they are nade in the EU. Price was $121. Local mechanic fitted them for $20 and a six pack. Very Sweet.
Hey,
wow thats cheap hugh well done and for the labor too well done. I like the 6 pack bit. LOL!
Sk by aby chance whats the reference for the Lucan for the brembos pads? I want to check how much are they. Cos i know a place they wanted like $200/paor of fronts. If i can save abit more its going to be cool.
  • 1 month later...
Hey guys.
I need some replacement discs and pads for my S2 RWD turbo stag.
Does anyone have any ideas on part numbers and sizes for these? I have heard they are different to the 4wd and non turbo brakes and the discs may possibly match to r32 turbo?
Anyone have any info?
Cheers!
The dimensions I was given for the front rotors for an S2 Stagea were off an RS4. I have fitted the R33GTST rotors to an S2 RS4 and they fit perfectly (after machining down the 6 mm of course). So I can only assume that the RS-V is different. The way to confirm this is to measure the standard RS-V rotors.
These are the dimensions of the RS4 front rotor (R33GTST in brackets);
OD = 290 mm (296 mm)
New height = 54 mm (54 mm)
New rotor thickness = 28 mm (30 mm)
Minimum thickness = 26 mm (28 mm)
Centre hole ID= 68 mm (68 mm)
Studs = 5 (5)
Obviously the dimension in question is the height (ie; 54 mm).
It is worth mention that ALL R32's, R33's, R34's (including Brembo equipped ones) plus S14's and S15's come with front rotors of 54 mm height.
There was sufficient room (with the pistons fully retracted in the callipers) to fit the Bendix brake padss, ie; the extra 1 mm of rotor thickness (each side), was not an issue.
:D cheers :rofl:
  • 5 weeks later...
  • 3 weeks later...
I just redid the entire brake system on the Stagea
DBA slotted fronts as per this thread
Bendix 1250 front pads
Bendix 1144 rear pads
Genuine Nissan rear brake discs
Genuine Nissan rear handbrake shoes
Rebuilt all the brake calipers (new seals, new pistons in 1, cleaned, some silver coating, greased)
The total was about $1250
yeah they have been perfect.
With the stock brakes I used to get fade after more than 1 stop with the car trailer on the back, and if I was giving it a thrash. No fade at all yet with the 32 gtr/rbf 600/bendix ultimates/dba4000 rotors set up.
My S2 upgrade consisted of R34 Gtt brakes, front and back, only difference from the R33 GTSt is that the front rotors are larger at 310mm, fitted nicely under the stock rims, about 3mm to spare. Front calipers also have longer mounts.
DBA R34Gtt Rotors, R34Gtt wreckers calipers(rebuilt),R32 GTR goodridge stainless/teflon brake hoses and MINTEX Xtreme pads.
All work perfect
Edited by chook
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
