I will be doing this, possibly this weekend or next. Hoping the stock 18 inch autech axis wheels clear the caliper. Otherwise spacers will become my best friend.
I believe that the DO fit behind the stock AXIS rims.
The double flare seat..is this the olive in the brake line connection point in the calliper? I threaded a screw into the olive to pull it out. Sounds the same as the R33 GTST calliper install but without the hassle of bolt spacers.
Sounds like the best bang for buck.
Thanks for the quick reply.
I have 20"s so clearance is not a problem =)
Spot on; that's exactly how I pulled mine out too.
It's a doddle to get them on, and easily the best bang for buck brake upgrade.
  • Like 1
Weird how R33 GTS-T brakes are an upgrade for Stagea..
From a car that's 400 kg lighter.
What am I missing ?
From memory R33 stock rotors were tiny as..
just the fronts;
c34's are 280 twin piston.
32gtst are 280 quad piston.
33gtst are 296 quad piston.
34gtt are 310 quad piston.
32gtr non vspec are 296 quad piston.
32/33gtr are 324 quad piston.
its kind of odd they didn't come with better brakes, but they aren't a performance car so they didn't need anything special.
So, are 34 gtt calipers the same as 33 gtst apart from the 14mm mounting bolts?
I'm assuming you don't need to trim the backing plate with the 33 gtst rotors.
No; the mounting legs are longer to accommodate the 310x30mm Rotor, as opposed to the 296x30mm Rotor from the R33GTS-t
  • Like 1
For info.
M35 front
296x24mm
R34 GTT
310x30mm
So a huge difference in warp resistance as well as increase braking force.
Exactly.
Not necessarily a huge step up in braking depending on the pads; but a huge step up in pedal feel (stiffer caliper) and repeatability.
Great step up withouy having to swap out the bmc
Pretty sure that even the old (now discontinued) AP Racing 8 pot front and 6 pot rear kit did not require a change to the BMC.
Edited by iamhe77
Pedal is defiantly softer than previously so there is certainly a Caliper volume difference which would now equate to more rear bias.
Glad to see these gone
Clearance is only 3-4 mm to the rim. Only thing that will prob snag people. I peeled the dust cover off like opening a can
Matt
  • Like 1
I think you had better bleed the calliper again. Did you clamp the line at the calliper before removing the banjo? Otherwise it's a pain to rebleed the abs.
It took me hours to bleed the last set of Brembo's I fitted, mainly as they were rebuilt which means there was no fluid around the piston. It can take a few decent pot holes to get the air from around the pistons to escape. Sometimes I tap the callipers with a soft hammer to release the bubbles.
If it's spongy then likely it has air in the system still.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
