I just redid the entire brake system on the Stagea
DBA slotted fronts as per this thread
Bendix 1250 front pads
Bendix 1144 rear pads
Genuine Nissan rear brake discs
Genuine Nissan rear handbrake shoes
Rebuilt all the brake calipers (new seals, new pistons in 1, cleaned, some silver coating, greased)
The total was about $1250
so the dba slotted rotors I got off you a year ago fit, hey Alex?
arranging my tuner to fit the rotors, front pads and allround Maltech braided brake lines, mid next month
Got some genuine Nissan Pit Work Stagea Series II 4WD front brake pads from Japan the other day and this is written on the box:
Part Number: AY040-NS129
Fuga [Y50]: VQ25DE, VQ35DE - '04/10-
Skyline [V35]: 350GT - '04/11-
Also stamped into the pad itself: HITACHI HP63H FF
I have a sneaking suspicion rwd & 4wd are different but I could be wrong
I hope this helps anyone still looking for their SII
If you need more info (pics/measurements etc) just ask!
I find the stock Stagea brakes are good if you have a good pad in there...and trust me I drive it as if its a sports car so braking is very important to me.
not me
even with endless pads and stainless lines with better brake fluid
i was still getting brake fade and other random problems
once i switched to drilled rotors/gtr brakes/and changed the fluid again to some trust fluid
it was golded on the touge
anybody familiar with the 260rs brakes (discs and pads?) i would imagine they are the same as the 33GTR? Wats the 33gtr specs? Like wats the part numbers for the rotors (DBAs) and the part numbers for the pads (bendix, ferrodo ETC). Thanks
Edited by stasis
  • 3 weeks later...
Hi guys,
I hope I'm not asking a question which has been asked before - I have searched. Just like to confirm I have this correct...
Series 2
Front Disc Rotors - DBA 4963 (R33 GTST) modified by machining down the OD by 6mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
DBA have these in stock currently
Rear Disc Rotors - DBA 4908 (R32GTR), modified by maching down the OD by 5mm, all of the other dimensions are the same. Unlike the Series 1, this is very minor machining, I would not expect any problems with this, we do it all the time on the race car rotors.
Does this mean that a 33 GTST rotor will fit the front of a series 2 stagea, *with* machining down of 6mm? Or without machining? And same with 32 GTR to fit rear of series 2 - it needs the 5mm reduction of OD?
Not talking about the DBA rotors, but stock 33 GTST and 32 GTR parts.
Thanks!
daveb
hi all,
bought some front pads for my series1 stagea using the 1398bendex number
said dont make these anymore but got me lucas pads instead
thought the part number might help people
no. lucas pads gdb3273
also says on box that these are used for
nissan infiniti(usa) o1.98>01.94
nissan leopard 01.93>
nissan maxima qx 10.94>
hope this info can help other stagea owners
Hi guys,
Thanks!
daveb
i have r32 GTR front and rear brakes on my stagea, no problems
My setup, using Castrol Dot4 super response fluid
Rear:
Stock discs
Bendix Heavy-Duty brake pads
Maltech stainless steel brake lines
Front:
DBA slotted rotors
Bendix Advance brake pads
Works very very well in the urban environment. Impressed actually, considering it hasnt been a huge upgrade. Peddle feel is nice and progressive compared to braking performance. Gives me confidence to stop in a hurry if need be. never had an accident before......
Hope that this has not already been covered.... Understand that there are few R33/R34 brake upgrade options but only really need a basic set-up.
Getting some pulsating when brakes are pressed. Local mechanic tells me that my discs are warped but are too thin to be machined. He has offered to order some original Nissan Stagea replacement rotors ex-Japan but I would rather get something done locally to save time and $$$!
Need help from a brake place in Sydney that knows some stuff about our Stagea's & can fabricate / replace brake pads + rotors.
Thanks guys.
Edited by stag
Thanks guys.
You might want t to check the GB section. Theres an ongoing GB for RDA (ithink) brake rotors. Very cheap. You might want to give him the dimension (diameter of your rotors and thickenss) and he will sought you out. Get the slotted ones don get the dimpled onr cross drilled ones as they might crack under heavy use. Let us know if you have any problems
Yudy
Stasis,
i just sent rs73 a pm re: rotors for my S2 Stagea. I did a quick 'stagea' word search in the thread but could only find ure post re: "for A Nissan Stagea it has the R33Gtr Brembo brakes on it. How much for a front and rear? Std, slotted and dimples?...." but no answer.
Did you end up getting them? If so how do they compare to the standard rotors, did you install them your self or how much did you have to pay to get them installed.
Also, what brake pads are you using.... Will be sure to get the slotted ones :worship:
Duncan,
Will give Grey Imports a call tomorrow... are they the ones in Annandale???
Maybe Nathan can help me install the rotors i get from the group buy mentioned above!
Thanks for the contact!
Edited by stag
Stasis,
Did you end up getting them? If so how do they compare to the standard rotors, did you install them your self or how much they you have to pay to get them installed.
Duncan,
Maybe Nathan can help me install the rotors i get from the group buy above!
From memory the sloted front is A$300/paor delivered which is preety good price. I havent got them yet. My rotors will be in for another set of brake pads before i need to change them. I will be getting this rotors for sure when i need them. Im using endless SSS now it came with the car when i imported it in. As it is estimated at 30% left on the pads, i will be switching to EBC Green. Reason is my rears have EBC Green ATM. I prefered Ferrodo though. Cos they say its better to use the same brand pads for front and rears as their coefficients are the same but somo people might think it doesnt matter. I prefer Ferrodo they are only AS$50 buck difference in price between EBC and ferrodo. Its up to you really. Boys on the budget?! EBC, not so on the budget?! Bendix or Lucas, spoil yourself?! Ferrodo. It also depends how you are going to use the car. Normal driving or track? If normal driving EBC or bendix should be ok. Hope this helps.
Yudy
Yudi,
rs73 tells me that he may be able to source some rotors specifically for my S2 RS4's but wanted to check over all dimensions before he can confirm. Have let him know that i will be taking her to Grey imports next week to see what my other options are. On a budget so will probably go for EBC or Bendix, dont plan to take her to the track at this stage :)
Duncan,
Spoke to Nathan earlier today and have booked her in for next week. He mentioned that he has recently done yours & may have some rotors in stock that will fit mine. He sure sounds like he knows what he's on about. Will let you know how it goes. Thanks again for the hook-up!
Edited by stag
Yudi,
rs73 tells me that he may be able to source some rotors specifically for my S2 RS4's but wanted to check over all dimensions before he can confirm. Have let him know that i will be taking her to Grey imports next week to see what my other options are. On a budget so will probably go for EBC or Bendix, dont plan to take her to the track at this stage ;)
Duncan,
You taking your car to grey imports for? For the brake rotors or the pads? If for the rotors i dont think you will find any cheaper RDA rotors around for that price.
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
