Hey,
I'm trying to come up with a custom plate for my R32 (Black GTS-T).
I only have a couple in mind, the one I really wanted 'NOT HIS' was taken so I'm after some ideas, if anyone has any post em up plz, would love some help :D
Thanks,
Loz
https://www.sau.com.au/forums/topic/82102-after-ideas-4-custom-number-plates/
  • Replies 41
Here a few off the top of my head if I was a girl...
WASHIS - (was his)
QIKCHC - (QUICK CHICK)
QIKGRL - (QUICK GIRL)
ALLMYN - (ALL MINE)
ITSMYN - (ITS MINE)
MSGTST - (Miss GTST)
ALLGRL - (all girl)
MISSKY - (Miss Sky..Line) Although someone might think its Miss KY (Jelly)
WASHIS - (was his)
ALLMYN - (ALL MINE)
ITSMYN - (ITS MINE)
ALLGRL - (all girl)
lol someone MALE might think of KY jelly!
Thanks for those :D I had ITSMYN written down as well, I had NOTBFS (Not bf's) because of how many times I've been asked "is that ur boyfriends car"
IZMINE - is mine
FEM32 - female32
PUREFM - pure female?
FEMPWR - female power
ALLCHK - all chick
QWN32 - queen 32
any tickle ya fancy
Is SKYGRL taken or is it SKYGAL that i keep seeing around?
How about a non-sex orientated one? Id like to get THE 032 when the standard plates come around to started with T, which is soon i think, if not already.
Grrrr SKYGRL is taken yes, you would of seen her driving around, not too happy that its gone! SKYGAL I thought I might see if its available
My plates on car at moment start with T, so they are around now
Yer it doesn't have to be gender related, just something I liked the idea of, something with chick, girl etc. in it, I'm a girly girl apart from the fact I like cars, enjoy talking about cars and have a skyline.
The plates will be hot pink anyway haha might not need to state gender... :D
NOT HIZ (not his said with gay lisp)
MYN FKN (mine farken!)
NO BALZ (no balls :D)
HER R32
IHERSI (hers in between two lines, works usually)
GRRRRL which was something I wanted to get for my gf ages ago
SISTAS
BBYGRL (baby girl?)
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
