We've got an R32 GTSt that had a an RB20DET in it, that has now been swapped over to an R33 RB25DET, but the RB20 wiring harness still remains.
We wana put a Power FC on it, but to do this, should we get an R32 RB20DET AP Engineering PFC, or swap the harness over and just get a normal R33 RB25DET PFC?
Any got any experience on this one?
https://www.sau.com.au/forums/topic/82127-pfc-and-rb25rb20/
If you want to run the VVT, then the R33GTST wiring harness and PFC would be the go. This means you use all of the RB25DET sensors so they match the harness plugs and the PFC.
If you don't want to run the VVT, then swap all of the sensors over from the RB20DET, plus the inlet manifold and injectors (they are top feed so much cheaper to upgrade than the RB25DET side feed). Then you can use the RB20DET wiring harness and PFC.
:D
https://www.sau.com.au/forums/topic/82127-pfc-and-rb25rb20/#findComment-1489378
Thanks mate.
The VVT isn't really a concern. Had planned on swapping over the manifold and sensors anyway so that should be OK with the AP PFC then.
The injectors, is their anyway to made GTR injectors work? These are top feed hi imp right?
https://www.sau.com.au/forums/topic/82127-pfc-and-rb25rb20/#findComment-1489413
Thanks mate.
Just curious
why would you have to swap to the rb20det inlet manifold wouldnt you just have to swap the sensors over ???????
That's why I suggested swapping over to the RB20DET inlet manifold, they come with top feed injectors standard. Then it is simple to fit GTR (also top feed) injectors or any number of cheaper (than side feed) aftermarket top feed injectors.
https://www.sau.com.au/forums/topic/82127-pfc-and-rb25rb20/#findComment-1491849
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
