Well my car is coming close to 100,000 km's on the ticker meaning I've got a serious service to save up for I'm assuming.
Just wondering what your 'typical' 100,000 km’s service consists of & how much it might cost?
Can the costs be reduced if say I order some of the parts myself. I know I'm going to need a new timing belt, & new exhaust & turbo gasket. I’m sure there’s plenty other parts too.
I’m in Syd ‘Northern Beaches’ too so recommendations to mechanics in Syd would be appreciated. Just along as they don’t cost an arm & a leg. I found my local mechanic around the corner in Newcastle was great, cost f#ck all & did good work. I usually like dealing with the smaller mechanic shops, more personable & cheaper.
https://www.sau.com.au/forums/topic/82131-100000-kms-service/
Probably look about $1k
Cost me around $1k included:
Timing belt
Water pump
Cam Seals
Brake Pads
Brake machining
All oils/filters (diff gbox etc)
Tune
Pulled starter motor apart and cleaned it (was making horrible noises)
And lots of other small random things, perished lines etc.
Now I did the plugs oil/filters myself and bought a new O2 sensor so this made it slightly cheaper
Timing belt
Water pump
Cam Seals
Brake Pads
Brake machining
Tune
Hmmm ok
I've already had:
Brake Rotors Machined
ECU Dyno tuned
Starter motor rebuilt *mine was making fuct up noises too hahaa.
Things I'm wanting to get done is:
Re oil everything 'like LSD yeah...
New timing belt 'that goes without saying
New exhuast manifold gasket & bolts '1 Bolt snapped & have a minor minor leak which would be eating away at the gasket.
The rest should just be the typical 100k service business.... Maybe I should just get a GT 3040 & new manifold while all that gear is being removed for the service hah. I wish.
Thats the way I was thinking, and now im selling my car because of it, such a money pit.
I used to spend a bit of money on my car, but since I moved outa home to sydney I simply dont have the money to spend anything on my car anymore it sucks, it's forced discipline really. Most my money goes into bills & big Saturday nights now...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
