Hello everyone...
I have a little bit of an issue here; to do with the R34 GTT and its performance (general running, and not power). It's an Tiptronic Auto.
My main issue is the fuel economy and the next issue is the power...
Now, many of you have suggested getting an aftermarket management system such as the SAFC II or the PFC (seems to be top choice). However...
My mechanic said it would make close to no difference in terms of better consumption or performance - is this true? or is it bullshit?
Secondly, since I have the Tiptronic Auto, which management system would work? Again I've been told several stories here: some say you need a piggy back system, others say stand-alone works just as well. What does work, and which one is ultimately better?
Your godly advice is very very much appreciated.
NOTE: In the not so distant future, the o2 sensor, oil filter will be changed as well as adding injector cleaner - in a bid to jack up fuel economy numbers.
https://www.sau.com.au/forums/topic/82132-to-tweak-or-not-to-tweak/
well... technically its wrong but what he is saying is what happens in the real world
let me explain...
skylines run rich... right? so with an aftermarket mnagement system you will lean it out and make more power at lowe rpm so theoretically you will save on fuel
BUT... what do you do when you have more power? you use it! so as a result of having the aftermarketmanagement system you give it that little bit more which makes the theoretical fuel economy saving mean nothing.
Warren.
The only way the aftermarket management (not safc) could improve fuel economy is to slightly lean it out furthur than 15:1 on light load and cruise. Also extend how long it stays in closed loop mode. Play with ignition timing at light load and cruise.
Together it all makes a little difference but not much. If your not getting over 400km's per tank easily then something is wrong.
Pull the injectors out get them cleaned, check for airleaks, check compression etc and replace the 02 sensor.
Do the cheapest or what appears to be the problem first.
i.e if its idling a little rough clean the injectors. :cheers:
    • Damn, as someone who just glued the damn things in (very slightly askew but better) I wish I saw this, or someone made this. Would be worth linking this to Boosted International. They're always looking for product ideas and this is something they would likely make.
    • You know what, I'll double or nothing. Save your money, buy a V8 Manual Mustang in 2 years and have a more fun street car with better support and all that. I often tell people "if I could do it all again, I wouldn't". Sell your R34 GTT to someone, spend the 20k in difference between that and a 2018 Gen2 V8 Manual Mustang. I'll bet you will have the $ in your pocket by the time you spend the ~20K differential on mods and get them installed. Just planting this seed for future regrets. Blah blah, wisdom of people who would do it differently who are at the end of the road you are just starting on, etc. Car modding is often death by a thousand cuts as you wait to afford the next big mod. Imagine a 2 door Skyline with a 330KW N/A V8 Revving to 7500rpm like the RB25, with 315's all round.
    • Yes I'm going through a similar thing with my R33 with rust in seams due to dried out seam sealer cracking. After much research I settled on Penetrol. Read what it does and its done a bloody fantastic job for me. Pressure pack comes with a thin tube to get into hard to reach places.
