...you'll only get rid of the 200SX in a couple of years to get the GTR you always wanted, so why not short cut it and go straight to the GTR!
Ive actually already owned a s15, the only thing thats holding me back is ide have to import one through a broker - and the risks involved with that obviously. But what you say makes a lot of sense :)
