Hey.
Well cracked a piston ring in my car so i ended up ringing around and found a mate with an RB20det head and bottom end cheap so i grabbed that.
Motor was from a late modle Cefiro 4WD auto.
Had to do a few little modifications like the sump but other then that we just bolted on everything from my old motor onto the new one and dumped her in.
The problem is that when it was all together and in everything wired up it would turn over but wouldnt start. Straight away started thinking timing but checked once, checked twice, checked 3 times and the cam gears where lined up with the factory marks etc.
Next, tried moving the crank angle sensor around but still wouldnt work, un did the bolts off it and moved it around more and it did start and was running fine. Problem is that where it is to be running is around so that the crank angle cannot be bolted down in the correct holes..
So obviosuly something somewhere is not lined up correctly..
The guy whos doing the motor swap just asked if i can manage to find a picture of the cam timeing marks or something which can help him..
Alternatly does anyone know what could be wrong? Where useing the Crank angle sensor off my old RB20 if that would matter at all?
Could the cams be different to the ones from my old motor?
The old motor was from a R32 GTST im pretty sure so yer is there any difference..
Please can someone help with ideas or hopefully know whats going on??? :D
Cheers :(
https://www.sau.com.au/forums/topic/82152-rb20det-timing-problem/
Check the cam timing..
Different cams won't cause it not to start. Hell the stock ecu ran the rb30det in fine and that was running a rb25 head with different cams, bigger valves and bigger ports. :D
I'd be inclined to say the cam timing is out.
Its very simply to do.. Line up the crank at TDC then the both cams at TDC.
If the dude doing the engine swap can't find the marks or doesn't know where to look I would seriously doubt is ability. :(
nah he has everything lined up, the cam gears are lined up with the marks on the plastic back part and he said the cams are lined up as well... Hes going to work on it again tomorrow and said it should only be about an hours work but i thought id ask on here anyway...
would it have anything at all to do with useing the crank angle sensor off the other motor? i would say not but just to be curious???
My car has an EMS computer as well if thats anything to do with anything??
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
