I am pretty sure that the factory boost cut(fuel cut) is around 1.1bar, the car will prevent you from boosting higher to stop damage to the turbo. In general you should have the cut left on if your using the factory ceramic turbo.
Once I had my boost controller put in then I can set the boost cut limit, therefore I think it is related to the boost solenoid/actuator rather than AFM, but that's my best guess.
If you are running a bigger turbo that can go past the factory fuel cut then I would suggest investing in either a boost controller or an aftermarket management.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119074
the fuel cut happens when the computer reads 4.5v or higher from the afm usualy around 1 bar on the standard turbo
you can over ride thif function in 3 ways
method 1 : lower your boost
pros : no more fuel cut and cheap
cons : lower boost ?? not an option :P
method 2 : fuel cut defender. this unit tricks the computer into thinking the afm never rises abve a preset limit usualy between 4.3 to 4.45v (user adjustable)
pros :cheap $100 -$300, easy install
cons : will lean out your engine if not set up properly,
limmited use will only allow up to 4 or 5 more psi dependig on your fuel system
method 3 : new ecu
pros: yeah baby i can do anything now :P
cons: $$$$$$$$$$$$
currently i am usinf a fuel cut defender untill i can afford an ecu but it works well for me and i have a larger turbo than stock and am running about 14 psi(the fuel cut would come on at about 8 psi with new turbo as it moves so much more air through the afm)
works well for now and i made the fcd myself if anyone wants one let me know or pm me
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119099
Another thing to keep in mind with the RB25DET ECU fuel cut.......
As the ECU uses the AFM voltage signal (anything over 4.5V) the point it cuts will vary depending on air temp & density. A modified RB25DET still using the stock ECU may well hit the FC @ 8-10psi on a cool night, yet it'll run 10-12psi on a mild/warm day without a hitch.
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119321
Originally posted by DAMQIK GTS-T
I would love to know how to make one,
A circuit diag or something would be great
Regards
DAMQIK
im not keen on handing out cct diagrams as i spent a lot of time developing this cct and fine tuning it to be better than the brand name ones which still fuel cut every now and again.
but i will make them and sell them to whomever wants on just let me know it costs me about $65 in components im asking for $80 ea for them. i think that its a reasonable price for my time
ill also give wiring and setup instructions( or do it for you )
i currently have on setup in my car so if you want a demo let me know
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119399
why not just get ur ECU remapped/reprogrammed? or can u not do this with R33s?
which gets rid of all the fuel/speed/boost cuts or whatever... mine cost me like 300 and with the ECU remapped to work better with my setup it runs better
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119644
Originally posted by Steve
EDIT: sorry if this is drifting off the original theme of the thread:
Whatsismane,
Would this mean that if you tune your car on a hot day, on a cold day as the air is alot denser it could throw out the air fuel ratio and cause detonation?
Steve
Steve,
No mate. The ECU is still aware of exactly how much air is entering the engine regardless of temp & density. The AFM will register the cool denser air (via the increased voltage signal) & ensure the fuel requirements are met to maintain the programmed A/FR.
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119656
A bit of a story to this one, so bare with me.
I've got a late 1995 GTS-t.
A while ago I blew the tacho output on my ECU (do'h).
I used the blown ECU for a few months, and while it was in I got a big FMIC. All was sweeeeet :D
I since got a second hand ECU and put that in. Tacho works well now but it feels like I'm hitting a fuel cut of some kind around 5000rpm.
It doesn't stop, but it does slow down heaps (acceleration).
I compared the ECU's and it looks like my original one has a different firmware installed (a later number is stamped on the main ECU).
Soooooo, is it possible that different year ECU's had different maps? or better refined maps or fuel cuts???
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119658
G'day J,
I'm guessing it's time to welcome you to the RB25DET ECU timing retard! Once the airflow goes above the AFM voltage range it pulls lots of timing to keep everything nice & safe. It just so happens that the nice denser air your FMIC is allowing has caused the above to happen.
I'm also guessing that once your AFM voltage drops drop back into its normal operating range (retard timing - less power & less airflow) that the car comes on strong again. This is because ECU has advanced timing once again (probably ~6000rpm).
The more air through the AFM the worse this will get. I had 3 big ECU commanded timing retard dips in my power curve @ the 225rwkw mark. These can be felt as huge flat spots, & seen as brief 15-30rwkw drops on a dyno run.
Having said (written) all this sometimes there's freak ECU's that don't seem to retard timing!? Bugalug's car is one of these! Like your's J, Bug's is a 95 model too.
Options to get around this issue are just the same as MYGTST listed to avoid the fuel cut:
Programmable ECU
Z32 AFM & remap - not easily done on the 33
Fuel cut defender - "can be" dodgy/dangerous
Turn down boost - yeah right!
Do nothing - & drive a car that feels like someone keeps pulling the handbrake on & off!
Why doesn't the timing retard & boost/fuel cut occur @ the same time? Buggered if I know? Anyone???
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119683
the timing retard happens when the ecu senses higher knock values which is at the engines peak tourque about 4500rpm-5500rpm the afm voltage may not have yet reached the fuel cut limit
i noticed this went away after i put in a bigger turbo as the air charge was cooler and it didnt knock anymore at the same boost level as the standard turbo
you can stop thisfrom happening by trurning your timing back a degree or two with the cas (side effect a bit less power) but much safer then detonation
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119716
Ahhh..that is what it is on mine most likely! Few times when i really stomp it there is like a flat spot where it seems like its missing or something but its only sometimes and with 100% THR (and its not the rev limiter as its before then). Seems to depend on the outside temp though as it doesn't happen that frequently.
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119743
G'day Matt,
Thanks for the info :D Looks like my next mod will be a PFC and a Z32 AFM....... I'll try and get the old ECU working again. I opened it up and found a burnt resistor and a transistor that got so hot it unslodered itself from the board !!! Replaced the resistor and put the transistor back in the right spot but I'm a bit worries about putting it back in the car incase it blows something else !!!
You had 3 !!! dips in power. Wow, I bet your standard ECU was crapping itself !!!
Predator666 - yepp, that's excatly what mine is doing :D I thought it might have been the plugs were crapping out, but nope, it's gunna cost me more than a set of plugs......
J
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-119800
Hey Guys/Girls
I have found this simple circuit that makes a fuel cut Defender
Try this at own risk!
I'm yet to build one myself but will be doing so shortly
Regards
Damqik
(Damqik i have remived the link here because if anyone uses this
curcuit they will dammage their engine i have already tried this curcuit and it leans the engine out big time)
(MARCIN)
https://www.sau.com.au/forums/topic/8217-fuelcuts-questions/#findComment-123541
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
