Well finally i bit the bullet and bought some Toyo Proxies RA1. These are a race tyre but are street legal similiar to the Bridgestone RE55. Im not expecting a very long life out of them but when you spend a fair bit of time spinning wheels, these are a huge releif. With the old Sumitunos HRZ 11's 255/40/17, 2nd gear wheel spin was at will as soon as boost hit. Good for showing off but not good for winning races. Now with these RA1's, i have 1st gear traction on the street and it is a rocket, no more hiding at traffic lights. Just for the record, i know RWD cars doing 1.6 60's with these tyres. Im not expecting 1.6, but if i can get 1.7/1.8 60's look out for a very low 12 and then i can drive it home. Perfecto.
https://www.sau.com.au/forums/topic/82245-traction-like-a-gtr-from-a-gtst/
The drag spec Nitto's is what you want for straight line.
They handle quite well also.
Whatsisname had them on his car when it was making some where from 260-290rwkw and ran a low 12 with his granny shifting. :P
I remember him telling me he can get almost all the power from first down and second also.
Where do you buy Nittos from? and how much are they roughly?
I just found this on Toyo's website:
The Proxes RA1 has the same construction & tread compound as the Nitto NT555R Extreme Drag Radial, and therefore provides very similar performance.
Don't know if I believe it but interesting... anyone know the price diff?
If Toyo's RA1 (which they advertise as a clubsport circuit racing tyre) has the same construction and tread compound as Nitto's NT555R (which is reknown as a drag tyre), then one of them is going to suck at their advertised function.
Drag tyres make shit circuit tyres, because of their weak sidewalls. And vice versa.
With the rubber compound and tread pattern, I don't doubt that the circuit tyre will provide good grip compared to your regular street tyre off the line, but its still not ideal.
Refer to my original post, I know guys using these tyres at the drags and producing awesome launches. As for me, my car now bites hard.
If they cant do both (drag and cornering) why do alot of quick street cars use RE55's and also Ben from RacePace uses these on his track GTR.
The Toyo's are a great "cold start" tyre. On the track they are awesome for the first 2-3 laps. From that point on they go off like "Mums pants on Father's Day". Excellent hill climb tyre and for street -the only thing to look out for would be to make sure they are not overworked too much. A lot of high speed continuous cornering would see them go off. Once they do, they become very "squidgy".
Good tyre though - except they will probably wear fairly quickly.
So far i have noticed, i can still get wheelspin in 2nd when they are cold, but once they warm up, grip is phenominal. Im yet to try them down the 1/4 as yet but im predicting a nice drop in my times. I dont track race so i can't adivse you, but i only have them on the back so i would be understeering quite badly.
So which tyres are good for track days?
Those bloody A032Rs....did you guys run the 48s? I am interested to see if they will be any better....I am hoping Gordon will be out of stock of the 32s when I need to buy the next set :P
Pete and Terry were having a tricky time with the 48s apparently?
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
