I have for sale:
a Motorolla a835.........................$200ono
a Game Cube two games a memory card and one controller........$130ono
a Power akoustik 450watt 12" sub and box..............$100
a 222 watt sony xplod 2 channel bridgeable amp...........................$150ono
a 10" sansui d-bass sub and box..........$100
  • 3 weeks later...
