Greetings All.
At the moment im planning out some future mods...
The focus of the engine is NOT max HP, but i want a very strong mid range and as little turbo lagg as possible...here is what i think...
  • RB26 Crank
  • RB26 Conrods
  • 87mm Oversize Pistons
  • CR 9.2:1
  • GT-30R Running 1 Bar
  • Adjustable Cam Gears
  • Mild Cams (Unsure of manufacturer, Thoughts?)
  • Intercooler
  • Plumback or HKS SSQ BOV
  • 3" Exhaust
  • Oversize TB & Z32 AFM
What do you guys think?? Ideas?? What sort of things should i look out for?? Would it be possible to run a CR of 9.2:1 with 14.5 psi on PULP?
Cheers,
--Tonba
https://www.sau.com.au/forums/topic/82268-rb25det-buildup/
Greetings All.
4000 RPM is too high, im looking for STRONG midrage torque so im looking for max power and torque between 3000 & 7000RPM...
Because im chasing midrange power/torque rather then max power id be happy with anywhere between 220RWKW and 280RWKW
I also want a turbo that wont run out of puff if i deside to pump up the boost and run race fuel for running times on circuit days...So at the moment im thinking of a GT30R or a GT28RS...
Cheers,
--Tonba
https://www.sau.com.au/forums/topic/82268-rb25det-buildup/#findComment-1491948
you want a 450hp turbo then without a doubt, even then full power by 3000rpm is going to be a mission if anything over 200rwkw
you want 280rwkw, your gonna have to live with it being mid 3000rpm... but for the odd 280rwkw on fuel... you wont need a built motor by any means
You wont get 3000rpm out of a GT30 no matter what you do.
https://www.sau.com.au/forums/topic/82268-rb25det-buildup/#findComment-1491977
Greetings All.
Ok, first off...Im not aiming for MAX POWER...so im not really aiming for 280RWKW...but it would be nice...
do you think that by increasing displacment and increasing static compression slightly i can reduce the lagg by having better off boost responce??...Would that improve the powerband?
I want a car that can be good on the track, rather then a dyno hero...
Oh also, i dont mind about mid 3000RPM...as long as im not hitting max bosst over 4000RPM...
Cheers,
--Tonba
https://www.sau.com.au/forums/topic/82268-rb25det-buildup/#findComment-1491990
read the rb30 bottom end conversion pages and doco's, speak to your local workshop/tuner ask them how much to have it done and then die when u find the price. nah seriously read the rb30 thread and pdf and come to your own conclusions. theres a few guys running this config and they post frequently in the rb30 conversion thread and will have covered pretty much any questions you have. you could choose a smallish turbo on it and have it absolutely tear up the rear wheels when it comes on boost pretty early or get a bigger one and have it come on progressively, being u can control it and put the power down. sure fit a gt28rs an rb30 bottom end it will probably be a bitch on the road. youll have like 100rwkw floor it and youll goto like 240rwkw instantly so it will wheelspin its ass off. again im only going off the rb25 turbo upgrade threads. look at a few of them then pick one thats nice, then work out what rpm it comes on boost at, then consider the rb30 bottom end work and you can probably shift the lag point down 500odd rpm maybe?
https://www.sau.com.au/forums/topic/82268-rb25det-buildup/#findComment-1492019
http://members.dodo.com.au/paul/pics/dyno/...bes-176rwkw.jpg
thats cube's rb30 graph. it makes 100rwkw at 2000rpm
http://members.dodo.com.au/paul/pics/dyno/172rwkw.jpg
that my previous rb25 graph with usual mods. it makes 100rwkw at 3400rpm
so you can see the difference in displacement
https://www.sau.com.au/forums/topic/82268-rb25det-buildup/#findComment-1492022
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
