have you had the same prob with your car
can't say I have, but if the computer doesn't get a reading from the AFM it goes into limp mode and won't let the car rev. Good place to start diagnosing...
firstly check the plug for the AFM, then if it's plugged in, unplug it and see if the car runs the same.
though maybe have a search in forced induction section, because it could be a common problem....
Thanks for the tip mate will check and see whether or not the afm is causing troubles...........
hehe,  sorry rb26 4-doors not welcome..... :huh:
:newbie:
lol checked the afm today there are no hassles there will have to put the lap link on and check again! From memory last time i put it on the tps was reading about 40 am unsure whether or not to adjust it to 0 and try it again.........
  • 3 weeks later...
have checked the afm & cleaned it the problem is still there intermittantly!!!!!!! Have been watching this for a while the boost still comes on but im thinking it seems to have a bit of fuel starve under accelaration so im going to attempt to get a new fuel pump and reg installed and see how it goes then!!!!!!!!!!!
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
