hey Nei try DMD there on the Ipswich Motorway service road just out from the magic mile (Moorooka) they're very good & not to $$$$$ give em a go, that is if you want some thing different & not a off the shelf thing.
But even then they will probably fit an off the shelf scoop for you anyway.
