Yes, Discopotato, you are right. Later I thought my comment didn't read well.
I asked whether the GT30 housing came as an unmachined or semi-finished blank that required finishing before fitting up. If that were the case (and doesn't seem to be), then the possibility could exist.
How then, does Garrett get the 56.5mm wheel mated up to the internally gated housing that they call a GT30 that is evidently very different to the externally gated GT3076 with its 60mm wheel? I say "evidently very different" because of their vastly differing flow/efficiency maps and the obvious different method of turbine speed control.
Do they both fall within the UHP family, and where is the information about that and NSIII?
Hopefully I will get it soon...
BTW I am going to kick off a thread about interpreting turbine maps just to keep the brain ticking over.
cheers
The GT30 and GT28 exhaust housings are very different internally both being based around their native turbine major diameters ie 60 and 54mm . They modified or cropped the 60mm to the maximum size that would fit in an overboared GT28 housing and came up with 56.6mm . The Hub is too big and heavy for the shortened blades and the blade form is not the best in shortened form . The GT28 nozzle form was designed for GT28 turbines and so not optimised for the diametre of the hybrid . Turbine efficiency suffers and shows up as lag .
  • 4 weeks later...
Great result quincy777, and right on target.
Couple of things I would like comment on if possible:
what sort of flange adaptor did you fabricate, and how did the turbo - suspension tower clearance work out?
what did you do for a suitable dump pipe
what is the boost threshold point (ie when does it go from vacuum to pressure)
how quickly does it build boost (once on boost)? Looking for comment about whether the power is controllable
cheers
Dale
Nice results for the 3071. When do you get full boost? Is it internally gated? Like the 3071-WG on atpturbo.com?
I get a bar of boost by 4rpm, internally gated and on standard manifold. Bought it from horsepower in a box. Lot's of fiddling and adapting with flanges, lines and crap but seems a great option..
I am planning to run one of these once I put some money aside (currently doing some serious body work!). From what Ive read around the place the GT3071R has almost the same spec front wheel/housing as the HKS GT2835ProS turbo. The main difference with the current breed of GT3071R is that theyre very common with a T25 Int Gate rear housing. Its been discussed around the place that getting the GT3071 with a 90 trim exhaust wheel and a HKS T3 .73 a/r exh housing is the way to go, as Garrett only offer a .6x and a .8x size in T3.
Housings are only USD$300 from HKS direct.
JK
  • 1 month later...
I've been thinking of putting a Garrett GT3071R on my RB20, do the RB20 manifold take T3 then?
Is this the turbo you lot are talking about? http://www.atpturbo.com/Merchant2/merchant...tegory_Code=GRT
was going to order it with 3in outlet ect.
But didn't know what you guys would surgest for A/R, i think i got the undertstanding that .82 is the one to go for?
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
