i have no idea about this
what does this mean????
i mech says
i need to relay my headlight wiring harness as my HID needs more voltage to start up
can any1 give me a simple diagram of this and explain it to me?? plz??
thanks in advance
my guess at what that means is:
-your HID's are setup to run from the exsisting headlight wiring harness
-they apparently need more power from their own dedicated 'harness', ie fatter wires with connection straight to chassis for ground and battery for power.
however if you just run new fat wires to battery for positive power and to chassis or negative battery terminal the HIDs will always have power, and always be on until battery goes dead.
so you need a switch to turn the HIDs on and off!
so we use the original light switch in the car!
and the original wires that power the stock light bulbs to switch a relay to turn on the HIDs.
my guess is that there is a positive power wire and a negative ground wire that power the lights.
with the stock lights, when you turn on the lights from inside the car that switches a relay which inturn will allow positive or regative power to run through the circuit. ie it is setup either to cut pos. or neg. power wires.
you need to find out which it cuts out with a multimeter.
(actually this may not be nescessary)
whichever one it cuts out, this becomes the 'trigger' wire.
because when u switch the lights on and off inside car, this wire 'gets' or 'loses' power. while the other is unaffected, and will either have constant pos. power, or constant neg. ground.
how a basic relay works is like a switch, but you flick the switch with another electric circuit instead of by hand.
it sits in the middle of a circuit,
ie cut a wire and hook up the two ends to the relay, and doesnt allow the power to go through the wire unless another circuit, also hooked up to the relay is turned on, thus switching the relay and allowing power to go through the first circuit.
wat u do is,
you cut your new fat power or neg wire for HIDs and hook that up to the in and out of one circuit of the relay. so they are constantly OFF ie not allowed to work.
then you use the pos. and neg. that your stock headlights use, and they get hooked up to the other in and out of the other circuit on the relay.
how this works is when you flick the switch in the car to turn the lights on, the power goes through the original light wires and through the relay and switches the new fat power or neg wire in the other circuit of the relay, and allows power to go to the HID's turning them on.
i hope you can understand this and it helps and is actually correct,
dan :)
https://www.sau.com.au/forums/topic/82379-wire-relay/#findComment-1498021
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
