Hi all, i need urgent help. my wipers just turn on themselfs after cleaning out my egine bay with the high pressure cleaner. the fist mark on the wipers dont work (ie slowest wipes) but the rest seems to be responding. they just turn on themselfs and its F**king annoying having them on while driving, this only occured recently.
i let the egine cool b4 spraying and i made sure i leave it there for like 2-3hrs b4 i start the egine again.
PLease help, i know it was not a good idea to spray water into the egine bay, but isnt that the best way to clean it?
any help would be great apprciated.
THANKS!!!
https://www.sau.com.au/forums/topic/82380-faulty-wipers-help/
nope didnt cover anything, well that a stupid mistake ive made, but i think ive fixed the prob.
i found the motor that moves the wipers, unplugged the clip,dried it with the blow dry, and there's a relay close under, turned that upside down *water drips out* :S. dried that too, and now the fisrt wipers mark moves when i wanted to :P YAY!!! hopes it F**king stay that way, the missis got very PMSi when we were driving in northbrigde with the front wipers going while its not even raining. LOL NOW thats cool (wipers certainly ****ed up my night)
things that pissed me off at first is that none of the fuse were blown so i knew i didnt arc anything, just the water bloodly set a few things off.
BTW jason, these are my front wipers soo i think pulling the fuse on them during winter is a VERY BAD idea.
holy crap you guys are psychic..
i was gonna post the same kinda problem.
My drivers side wiper shit it self the other night. Doesnt seem like a fuse thing, but like its mechanically stuffed. I was going down the free way with them on, and the driver side just extended all the way over the edge of the windscreen.
Once i brought it back down, it doesnt actually wanna move any more. The other wiper moves as per normal, with the 2nd one dead.
Any ideas as to where i can get get it fixed/repaired?
Prob broke one of the arms (under the black plastic at the bottom of the windscreen) same thing happened to me about a year ago, easiest to take the bonnet off to do it (on an R31) but you can struggle with it still on, as i did (was about 9pm, and was going to rain the next day, and had no-one to help with taking the bonnet off...)
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
