jus got my car (r31 gt passage) back from having a manual trans installed. it doesnt run very well, ie. not revving cleanly, makes a knocking sound when revved cold, this disappears when it warms up...
anyway, wheres a good, cheap dyno tuning place in bris, where i can take the car?
the car has a red top nics rb20det, r32 turbo (t28?) and zorst...
thanx in advance
https://www.sau.com.au/forums/topic/8239-dyno-tuning-in-bris/
Does it need a "dyno" tune? I've heard oodles of bad things about tuning a car on the dyno, mainly along the lines of it ends up tuned for WOT in 4th gear? Knowing very little about the subject, I woulda thought that gas analyzer would be better but maybe they use both to do a dyno tune in conjunction with each other?
Brisbane Tuning and Turbo at Woolongabba!
They where the second place on Brisbane to get a dyno...
And specialise obviously in turbo cars and dyno tuning..
Very good...
John Whittaker is the person to speak to..
Tell him Scott told you about it..
Good prices..quality work...
Only place I have taken my car for that sort of thing...
3393 1588
Guest nismogtsx
Top choice guys....
The guys there dont stuff you around they know what their doing and there for cost you less cause it takes them less time to do stuff...
Tell im that the boys from the skylines australia forums set ya... He know us...
Top choice guys....
Ditto.
Use them my self.
aha! excellent, i will take myy r31 into them next week, provided i can get the bitch started! i dont know whether i want to bother with dyno tuning as it seems too expensive, but these lads seem as tho they could figure out the problem with my car... its gotten much worse ie:
bacfires like crazy when revved to 3 grand
wont idle at all
its really pissing me off and i've already wasted time money and effort with the local workshop who have no idea what to do. do u guys reckon brissie tuning and turbo could fix my shit? its an r31 passage with the nics redtop rb20det...
thanks for your help
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
