  • Replies 275
Posted Images
7heavn: Why don't you have the R32 anymore?
Brad: What's with the OMG? It's not like you haven't seen a huge burnout pic of the 200 :rolleyes:
Adam: What was JETT's mph?
Definitely can't wait for the next one. The rotor guys are also pleased with the day and are eager for another day.
forall those interested,
JETT got towed straight to workshop with potential spun bearing,
1st run) was 11.1 @ 129mph without gas and 7000 rpm launch
2nd run) was 8500rpm launch with gas engaged but forgot to put it back into 4wd from rwd burnout, think maybe did some damage there bouncing off the limiter in 3 gears
3rd run) everything was ready but after burnout heard a knocking so limped it down the track for a 28second pass, my new personal best,
So now jett is at workshop getting rebuild and selling with new internals, if anyone interested in buying after reuild let me know, price will be reasnable.
Jett did at least one 11.1 before breaking.
I just couldn't get proper smoke happening or good launches.  Crap 60 footers and no smoke burnouts don't make for good pics I guess.
I told you mate, you have to step on the brake to stop the car moving forward to do a burnout. You can't just step on the gas and hope it stays in one spot.
We should get Adrian to give SAU'ers lessons on how to do burnouts, because considering that you were told in no uncertain terms that you could burn the entire length of the track if you felt the need, 99% of the burnouts done by SAU'ers left a lot to be desired :chairshot :bonk:
Guest DIRTgarage
That's a bloody awesome time - congrats to all involved with the car.
I actually had one run against you and I felt like I was standing still when you passed me half way down the quarter. I have to say that I now have an even greater appreciation of the raw speed of a legitimate 10sec car. That thing is a machine :rolleyes:
Thanks brendan.......i was thinking as i was roaring past, how bloody good would that sound, a 10 sec car screaming past at full noise.......i think awesome summed it up.
A huge thanks goes to our tuner Jim Souvas, who took time out from being with his family to attend....also a big thanks to Tom Miyamae our suspension expert. The boys from Croydon Racing Developments have helped in taking this car to the next level of performance....10.3 is a great achievement for what is essentially a home built car. Further development in key areas will hopefully see DIRT/CRD with an RH9, 2530 powered GTR.
i sat on it heaps of times merli !!
but just not alot smoke! gotta be the tyres, i left the day with the same amount of tread i started with.
does the beemer sit on the brake?
also wouldnt mind seeing your pics from the day!
Nope... Those 19" Pirellis are waaaaaaay too expensive to abuse like that :rolleyes:
Someone donate an R32 GTR for me to play with :uh-huh: :uh-huh:
Hey Andrew, where are your pics.... i would be certain you got some awesome pics you could share with us all :rolleyes::D
here is a small vid of the 200 if anyone is interested.... you can faintly here Merli telling Andrea "now thats how you do a burnout!!!!!" hehehe
http://members.iinet.net.au/~ferry/videos/...x_rb26_11.8.wmv
I hope that works by right clicking on it...
I'd also like to thank Adam & those who helped organise the day. It was awesome.
A Short vid of my PB 12.158sec @ 110.89MPH
You'll need the Xvid Codec to view it...
Not bad for an old mans car eh :unsure:
Go the all wheel drive.
I think I'm going to have to find a carpark to practice in :P
I think I'm going to have to find a carpark to practice in :O
I think I'll have to do the same thing next time. I've never really attempted 'burnouts' in the Skyline before and was only getting the hang of it by the end of the day :D
So, are there anymore pics/vids from the day? Seemed like there were a heap of people taking pics at the track, but I haven't seen that many posted up as yet :O
Guest DIRTgarage
I think I'll have to do the same thing next time. I've never really attempted 'burnouts' in the Skyline before and was only getting the hang of it by the end of the day :O
im gonna get some burnout training...cant stay off the limiter in 2nd...may have to try a 3rd gear burnout. Stood next to brad after his and his tyres sounded like flypaper....very sticky indeed!.
The quest for 9's
Car has 6 more psi to be dialed into it = more power. Have lined up a HKS ETC-EDA for more front drive, and have a spare transfer case to get modified to 12 clutch plates instead of 7. Didnt think i'd say this but "we will run 9's in this car"
your going to need a 4WD controller so you can make it a 2WD for the burnout Paul.... i dont know if its the right thing for a car such as yours, but a toggle switch would be ideal.... once its in 2WD the burnout will come really easy. I wouldnt suggest dumping it in 3rd as i think thats what has damaged the clutch in the 200 :O:( will find out soon enough though....
Once it gets more boost and a tune you will run 9's and it will be great to see it happen :O:) You just need to teach Stacey how to drive the car harder :D:)
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
