I believe that to be BS for a start.
But, it will depend how the 2 lights were disabled as to how easy it will be to enable them. If they have simply cut the wires, then simply re-join / re-solder them.
I personally disabled the 2 inner taillamps by simply cutting the wires. So now I have 2 tail and 4 stop lamps.
  • Like 1
well im guessing u have a series 1.5 or a series 2 skyline right? coz in series 1 all four lights up but in the 1.5 and series 2 only the 2 on the end on either side only lights up, if u wanna make it light up im guessing jst tap the wires if u want.
Guest tkch55
i'm sure the series 2 r33 gt-r have only the outer lights light up when braking
all 4 lights light up on all lower model r33s when braking, doesn't matter what yr model it is
however, some workshops disable two of the brake lights on the gtsts for compliance reason
according to adr, you can have so many rear parkers but only 1 can light up brighter each side for braking, check out the aus delivered r32 gt-r and the accord euro, they're good examples
Every series 3 GTR I have ever seen only illuminates 2 of brake lights. This includes two that I have owned, and neither had butchered wiring.
My S2 has 2 working, the wiring was butchered at compliancing. (All 4 were working when it was imported, then following compliance, 2 are working.)
Mine were hacked badly, so that soldering them back together will be a mess.
I'm jealous when I see another skyline on the road with all four hotplates on...2 just looks crap.
