They use a red filter over the flash at night time so the driver’s night vision isn’t reduced.
Trust me, when they take your picture of your car, the number plate is a white Haze/glare... its when the put the photograph to its opposite colours i.e. showing the negative of it, that is when they read you numbers on your number plate nice and clear.
Does anyone know of any license plate protectors to protect it from radical bright random flashes which occur on the side of the road?
if u guys dont know this site, u can thank me later but have a read everyweek it will save u and ur well loved lincense.
these are the official speed cam locations, u dont know what tme they "erect" it up for raping. but its worth a notice of caution when driving on the listed roads.
u can get plates covers but cops WILL RAPE u more if they see it, they work 100% but they are very obvious. PS this post did not come from me :rolleyes:
http://www.policespeedcameras.info/speed_c..._locations.html
why didnt we get it from you..
Why would you get in trouble
And does anyone know any other method of protection other than radar detectors
Apparently spray a whole can of hair spray over the plate was something that used to work! don't myself, not tried.
erm .... don't speed? :rolleyes: Or at least stay within 5 to 10 km/hr of the speed limit.
And as for 140 km/hr in an area that is either 60 or 70 km/hr, that is just madness and you deserve all you get. You could easily kill innocent people doing that, as well as youself - keep it on the track. (To admit you don't even know the speed limit, shows you had no intention of even trying to stay near the limit.)
Just thought you might like some grumpy-old-git input!
Cheers.
radar detectors are good but useless if ur doing 20km over or more, i got one its pretty shit, gives me about 20-50m notice, usually 2-3 sec to slow down b4 i see one in sight, im planning to upgrade it once i have money. any1 wanna buy it :rolleyes: whistler 1670.
all speed cam are Ka band, hard to pick up, lowed powered, always planted around bends, and pointed at low height ( usually at ur front plate where its highly reflective) soo u either get alot of false alarm for good radar detectors or shit range for cheapers ones. ;)
The cameras are set at the speed limit plus 10%.  ie  80km/h zone camera set at 88km/h, 100km/h zone camera set at 110km/h.  Then 1km/h gets droped off the recorded speed to allow for any allegation of camera error.
Keep your speed under the the 10% and you'll be right.
or... you could always do the speed limit in the FIRST PLACE!!!
was just done a few days ago, doing around 76 in a 60 zone :S
all because I wanted to get back at an arsehole in a 4wd tail gating me for the past 5km, so I decided to put some distance between me and him... 200 meters later red flash.
I can only guess 3 points and $150?
yeh red is wat they use at nite
south street is 70 most of the way then 60 down near freo
there is ALWAYS a speed camera on south street just up from Karel Ave exit i should no coz i passed that way everyday to work so youd have to be stupid to think they wouldnt put speed cameras on south st especially seeing as they can make so much money from ppl going 80 instead of 70
dam i go to murdoch uni nearly everyday in my s13 and have never spotted a camera near karel ave, or on south street for that matter, musta not be concentrating enough.
but without a roe hwy overpass, and all that construction, south street is so spammed with trucks u hardly get over 30k's anyway. :P
u can get plates covers but cops WILL RAPE u more if they see it, they work 100% but they are very obvious. PS this post did not come from me :P
Sorry..what's with the + sign next to some locations?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
