ok, I've got a RB26 transplanted in my cefiro, its been in there for a while now.
I run aftermarket Autometer guages, tacho, speedo, etc etc
The Tacho output off the computer is not working and has been tried on 4 different computers, including the Power FC which i am now running.
I have been using one of the Crank angle sensor wires in the mean time, but i have problems with the rev counter dropping after it reaches 6500rpm back down to 5500rpm then goes back up. It is rather anoying and finally i've had enough.
Now I have tested the tacho wire in EVERY single wire connection of the computer. Just to make sure i've exhausted posibilities, thats how i found the crank angle wire to kind of work.
The engine runs perfectly fine, so every wire that is needed for motor to run fine is connected. Any other wire off the computer is not connected. ]
My question is: Is there another wire that makes the tacho output wire work.
I have taken my tacho into another store that calibrates and alters tachos/speedos etc, and they reckon the tacho works perfectly and should read the 5 volt signal that the computer gives.
I believe a wiring connection is at fault and the computer is not outputting a signal. Would anyone know of anything that may help my cause!!
Cheers
Dayna
https://www.sau.com.au/forums/topic/82485-rev-counter-output-rb26dett-help/
The ECU doesn't output a 5V signal on pin 7, it's an open collector output that is grounded to generate the rpm signal.
Cheers.
Simon.
I would be more inclined to pull a negative pulse from the ignition. How the older vehicles used to do it by pulling a varying voltage from 1 phase of the altenator.
I've never taken much notice where the factory tacho on my rb25 has been picked up from... Plus not having diagrams sucks.
Cheers
Sumo
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
