seriously loud ride!
hey all,
my new r32 gtr has tein coilovers, not sure what model, but there is the most frustratingly loud banging noise from the rear over every bump!
i have never had coilovers before and these came with the car so i dont know what to expect, the car is not excessively lowered, guards are about 2inches off the rubber (i imagine its set to stock ride height).
there appear to be no other suspension mods.
but this deep banging/bumping noise is worrying me, i have only had the car 1 day and the clutch has died so i havent had a chance to try and diagnose the problem.
any suggestions/thoughts would be great
cheers
dan
btw im 99% sure its the teins everything in boot (spacesaver and tools etc) is secured pretty well
before you go to all that expense does it sound like a "loose" bang or a tight one? I pulled the back seats out and stuff to find something floating around loose beneath the parcel shelf. might be worth a look if it's a "loose" bang
no its a tight bang, its a metallic sound, but not tinny, very solid. and can be pinpointed side from side if i go over a bump or ditch with only the one side then the noise comes from that side(obviously)...
if fate decides a rebuild, would it be cheaper to just get bilsteins?
and any suggestions where to get tein's rebuilt in sydney (or australia!)
thanks
dan
thanks
dan
www.bilstein.com.au is the best place to get it done.
It's not cheaper to get a whole new suspension set up.
Bilsteins cost $250 per corner (x4 = $1000) and then its around $400 to put them in.
im guessing that means yeh theyre fooked? and im fooked because its not cheap to rebuild?
Well if you have no money to fix it up then yes, you're stuffed. :headspin:
You could go for a cheaper set of replacement shocks. I think Aussie made ones like Pedders will be cheaper.
Do you have any pics of your car?, MAYBE (i'm just guessing) that its the wheels you have MIGHT have the wrong offset and are sitting outside the guard so when you go over a bump, the wheels actually hit the wheel arch (makes a similar sound), i guess it doesn't hurt to look at every possibility (when i had the wrong offset wheels on my car, the wheel were actually sitting out of the guard a bit) so when i travel on VERY bumpy road it use to hit and make a very annoying sound.
yeh thats the thing, it came with these teins from the dealer...
its ok, its in the shop now,
its gonna get worked!
new rotors, pads, caliper rebuild, braided lines, fluid etc, all round.
new daikin HD clutch and all bits and pieces that go with it.
new bilsteins etc (not 100% sure what will need to be done here yet)
full check over and service.
all in all its gonna be an expensive exercise, but most definately worth it.
hopefully i'll just forward the bill onto the dealership...
(doubt that will work though)
dan
The dealer has a responsibility to sell you a car in working order. If the clutch failed as soon as you bought it, it is their problem to have it fixed and they are legally bound to do so as long as the car was not sold on the agreement of a rooted clutch. You should have gone to them first thing rather than paying yourself to have it fixed. I doubt forwarding the bill onto them will make them pay it.
My 2 cents....
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
