Car will not start but makes strange clicking noise - HELP
EDIT 3/8/05: Problem fixed for now - see post 12 below.
Been having a bad run with the line,
Had a minor bingle about 2 weeks ago, car was running fine after (only front bumper was rooted) so the car was sitting in my garage and not started for 1 1/2 weeks. Go to start it yesterday and battery was dead, no prob, it was on the way out for a while and I already had a new one. So I replace the battery and go to start it and when I hold the key in the start position I get this loud Click, Click, Click, Click, Click, Click, noise at about 5 Hz, comming from the somewhere up front. The motor does not turn over at all.
When I hold start the voltage drops considerably - I know the battery is good, besides I also tried to start the car with the car jumpered to another running car.
All this sounds like a rooted starter motor to me, but before I spend craploads on a mechanic trying to find out what is wrong - has anyone had a similar problem? Does anyone know what it couls be?
Any help greatly appreciated.
i had the same problem iwth mine when i imported the r32. i thought it was the alternator but when i took it to the auto electrican he found out the it was some weird fuse ive never heard of before or something. if i were you i would take it to the auto electrician. get him to ring you once he knows what the problem is then you can decide from there. im a cheap arse and if it was the alternator i would have bought a second hand one instead of paying a shitload for a new one
mine does that every so often, i just thought there wasn't enougfh power to run the starter motor properly and sounded like a clutch like device was clicking away, dunno, a quick push and off we went, starts properly now
It seems to be a problem in the starter circuitry. When I had that problem, my mech re-wired the starter solenoid so it got power direct from the battery (used the factory trigger wire to switch a relay). Haven't had a problem since.
I have had the same issue, but mine did it also when there was plenty of voltage (seen from PFC). I always figured the starter motor was not engauged right. All I do to fix the issue is move the car a little while in gear the the problem goes away.
I dont know if I am right with my theory but it works for me...
I thought of doing that but then I thought that the startor mortor is not engaged unless it is being cranked. I'll give it a go if it worked for you.
Mine does the exact same thing.. a couple of times a week I have to give it a bit of a clutch start..
That clicking noise is the noise that it will make when the battery cannot supply enough CCA to the starter motor (Cold Cranking Amps). It makes this when enough voltage is present to turn the vehicles circuitry on but not enough to crank the motor. Check your battery voltage and then if that doesnt work get your wiring to your starter motor checked. If the starter motor was rooted I doubt it would even make a clicking noise.
I seem to have fixed the problem, I just played around with the power connections to the starter motor and gave them a quick cleen - have not had a problem since (3 days later).
Thanks all for your help, if this fourm did not exist I may have payed $200 for someone in a workshop to do the same thing.
Cheers,
Pat.
  • 3 weeks later...
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
