yeah that's weird, because standard they are 7PSI, but as soon as you remove the exhaust restriction the boost bumps up alittle bit, usually stock to around 8-9psi.
Can I ask why you're only boosting 7PSI? I'd be up around the 10-12PSI mark myself with your mods.
ummm stock boost levels are all the same... they dont vary unless the boost has been uped from factory, its not like nissan said... yeah k this one can have 7psi and that one can have 8... lol.
and yeah 12psi is the max the stock turbo can handle before it goes boom i was told, even with an fmic and such they recommend not taking the factory turbo past 12psi.
JaR - When will you start to modify your car? Are you still running the factory boost solenoid? You are aware of how to remove the 2 stage boost from factory? That mod was a goodie... :)
as soon as i get it back ( its gettin re-sprayed at the moment ). umm nah lol, but wasnt there a tutorial on here about how to do that??? had pics and all was really detailed from memory...
  • 2 months later...
and I am sure they also told you that 12psi or more, and the ecu goes onto the rich and retard maps? Dropping off about 30rwkw - 40rwkw, making your car surge like a bitch.
10psi is the best performing, until you get a better ecu.
So 10 psi,Turbo back exhaust, filter, fmic, power fc. would anything else be required if someone does these mods?? Like fuel pump,injectors etc?? Im wanting to do the above mods but want to make sure I do it the right way first time round with all the required equipment to make the car run safe but with alot more power.
My series 2 has similar mods to urs. Turbo back exhaust, FMIC, power FC, pod (did my own piping to get some more cold air in near the pod bcoz of the crap boxing it in) and bov. It handles 11-12PSI no sweat. no spikes etc. I havent intalled a boost controller which i been meaning to do. Just make sure u get your chip mapped spot on and you'll be sweet.
I heard stories about maybe upgrading the fuel rails or pump to be able to feed it high up in the revs. I gave it a go and found it didnt make that much of a difference. I was prob running rich, and didnt really tune it but it went fine without. Spose u dont want to be pumping to much juice in it these days anyway. Petrol prices are doing my a$$ in.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
