Hi all,
Im after an R32 GTR gearbox in working order.
Preferably in QLD, but obviously will be happy to ship from anywhere as long as price is good in first place.
Please feel free to let me know if you have one going.
thanks
Michael
https://www.sau.com.au/forums/topic/82520-wanted-r32-gtr-gearbox/
I got one in adelaide.
its a late model type to suit pull type clutch, but can easily be converted to push type by using your fork etc.
comes with the front shaft as a freebie.
$700 plus you to arrange freight.
I think TNT will do it for about $120
bingo ok, this was out of a working car?
any reason to think its damaged or was all ok, synchros were fine? Have u inspected the gearset no missing teeth?etc?
infact maybe we should talk via email
drop me a line
[email protected]
Intrested!
thanks
michael
Ive got one in Sydney its $500 plus freight, it is perfect for someone with a blown box as it needs the wirrings, sensors, shifter and slave cylinder replaced due to a fire the box itself is fine
email me if interested [email protected]
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
