Yeah they. You might have a little trouble with the offset, but play around a liitle, I assure you they do fit.
By the way...
"The R33 may be the inbred cousin, But the R32 is the slow, decrepit, dirty old Grandpa!"
But the R33 is like the Ugly duckling that didn't quite make it into a swan!! If you want a boat... go to JV Marine!!
Sava
Fulllock Motorsport
www.fulllock.com
https://www.sau.com.au/forums/topic/82526-stupid-question/#findComment-1497072
They will FIT onto the car, but not perfectly due to the offset, as someone mentioned earlier they will STICK out of the guard a bit, so if you car is lowered when you go over a bump road, the wheels will hit the arch/guards.
IMO i think you better off investing else where for something that will fit perfectly for a R33 gts25t you'll looking at 5x114.3 PCD and front wheels offset of +32 and rear offset of +37 i think (only guessing) GTR r33 wheels are +30 or lower.
thats my 2c good luck
https://www.sau.com.au/forums/topic/82526-stupid-question/#findComment-1497942
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
