Im hoping to install air temp sensors in the exhaust housing of turbo and intake plenum so i can get before and after air temp readings, have a company wanting to do ceramic coatings inside and out and as many of my engine bay parts as possible, they even wanted to take the sump off and do more coatings in there...
They are hoping to show coating benefits to customers in the real world, so temps all taken at track before and after
I ended up going a Perrin beanie, racers use them for a reason. I Also went and sourced a roll of INDUSTRIAL heat wrap and a couple of sheets of the ACL heat shielding. I've reduced temps massively doing this
  • Like 1
Reducing engine bay temps is one thing also taking advantage of the lower temps effects on the intake charge is another... So reducing outward temp of parts and then reducing heat that can heat soak others
The guys at GCG reckon the Borg warner Beenies are good for 800 Celsius which is fine for the street but may reach higher temps after some hard circuit work. Sprints and a few laps shouldn't see that temp I imagine.
Full-race also got back to me and they do ceramic coat and/or wrap their manifolds and they still give warranty against cracking. Not that I see why it should. Also noticed they ceramic coat their manifolds for 150ish bucks.
Should have had it done when I bought it as GCG quoted me $905 to coat my manifold, turbine housing and 1.5m of dump pipe.. seems steep
Whats the general thoughts on Turbo Beenie vs ceramic coated turbine housing in terms of reducing heat. I would imagine the beanie would work better
I wouldn't use a beanie if your car is used on a circuit, it will heat fatigue your housing. I don't think your turbo has a stainless housing but if its iron like 99% of housings it could be 1 year, could be 10 but it will fatigue crack and possibly warp if your doing regular circuit work. Drags and street is fine though.
Of course you can touch a beanie afterwards, they are 1'' thick! What cracks them is the surface temp/core temp differs and fatigues over time
Best bet is to make your own from ACL and rivet it together. Depending on how well you make it, it will be just as good without any risk. If you only spend 20 mins making it, you may as well make a heat shield out of cheaper mats
Competition coatings in Guilford will be 1/3rd the price on gcg, hi octane coatings etc.
Mine is a Taiwanese stainless Tial copy, still going fine after 4 years wrapped in a beanie. They are a lot thinner than a cast iron housing.
I doubt either will crack or warp just from the beanie, perhaps if the exhaust is hanging off it with no flex joint like most of you run your systems.
I'll give the guys at comp coatings a call then.
Someone previously posted that they wrapped their Intercooler piping.
I'm not sure what the purpose of this is for. Yes you may stop some heat soak but wouldn't it be better to keep the piping exposed to the air to reduce charge temps as appose to keeping the heat in
Turbo makes the air hot. Intercooler makes the air cold. The hope should be that the air coming from the cooler into the engine bay would be colder than the engine bay environment. Ergo, wrapping IS about keeping the heat out. This is especially true when stopped or crawling in traffic. There's no heat in the incoming air - so stopping it from getting hot between the front of the car and the plenum is a good thing. Allows you to make power without pinging if you suddenly want/need/get to put your foot down.
If the air returning from the cooler is hotter than the engine bay, then it is not going to lose much heat to the engine bay anyway. This would possibly be the case when you're on high boost and load and the intercooler is only able to get the air down to a still fairly high temperature. In this case, the wrapping may stop the charge air from losing a little more heat to the engine bay, but the engine bay is a pretty hot spot, so you can't imagine that the loss of cooling power from wrapping it would be worth worrying about.
FWIW, I have my return pipe wrapped in glass wrap and then reflective foil+bitumen tape as well. The latter because it is easier to wipe clean without glass fibres coming loose all over the place, pain of working with your arms rubbing up against glass tape, etc etc.
Edited by GTSBoy
I agree. It was good enough for Gibson. :P
Thanks for the post GTS boy
im thinking I will use a black wrap on the greddy hard pipe kit I have so it doesn't look sho shiny and gay.. stands out less on the pipes coming off the cooler in the front
where did you purchase your reflective foil and bitumen tape??
interesting what looks like support bars for the turbo/manifolds, certainly can be a heavy load hanging off the manifolds on modded cars. Is that to stop the manifold
cracking under hot racing conditions?
Edited by AngryRB
The cast manifolds turn to jelly at 1000+C, yes the bars are there to support the weight and keep the manifolds in one piece, seems to do the trick...
I needed aluminium tape and seen that tape in bunnings. Not sure if its the right stuff. I ended up getting aluminium tape from Jaycar for $11 rated to 120 deg c. It looks more like the tape used on the Gibson car.
Bunnings starts at like $26
I doubt either would do much on a greddy hard pipe kit, its already polished alloy
If you don't like the look just paint it with 2k or engine enamel (something that wont scratch easy) or ceramic coat it. Wrapping a hard pipe kit will add Zero gains. One hit on boost with 100deg + outlet temps from the turbo and it will be just as hot as anything else.
Have a close look at the Gibson picture, they "over trimmed" the manifold heat shields. They could have had warping issues due to temp so they were trying the "more airflow" approach then that caused a heat soak issue in pit stops.
TLDR Hot side don't worry about it or just paint/coat it for looks/preference. Cold side do what you can to stop heat soak only if you have long cross over pipes (rb20/25). RB26 is too short to bother with
Yuh, and on RB26 the return is on the driver's side of the bay. Stock pipe layout on 20/25 passes the return over the turbo, so worth doing what you can there I suspect.
  • 4 months later...
small revival,
whats peoples opinions on ceramic coating the external waste gate pipes?
I would assume there would be a small advantage in terms of keeping engine bay temps down, performance wise i'm guessing the gains would be minimal.
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
