Engine pretty much same... RB25
The main difference is in in the turbo between series 1 and series 2. The standard series 2 turbo has a plastic wheel turbo and hence can handle less horsepower then the series 1 ceramic.
Interior specs are different. To me series2 looks a bit more modern with more modern looking trim, but its fairly cosmetic and the front bar and bonnet looks slightly different. Airbag, drivers side airbag and ABS came a bit more standard on the series 2. Series 2 headlights are darker tint.
Otherwise they are fairly similar in terms of gearbox, diff, power, reliability, etc.
m spec question has been asked many times before... do a search
Thanks guys
damm right about the newbie, went for my first drive in one on Sunday, after checking out modifed 180sx etc ... previously owned turbo fours and a rotary .....
Really enjoy the ride and potential of the R33 .... have started pricing some goodies at JMS to help with the choices
There are quite a few cosmetic differences between the two:
- Different headlights (much better!)
- front bar with round indicator and spotlight (series 2)
- Dash fascia has rough finish rather than smooth for series 1
- Rear 'SKYLINE' lettering on bootlid is in same colour as car for series 2, as opposed to in clear plastic for series 1
- Higher boot spoiler on series 2, although did come out on '95 model series 1.
- Interior cloth trim different on series 2
Also you'll get twin airbags as standard in series 2, '93-'94 driver's airbag option, '95 driver's air bag standard. Not sure about ABS, I think it's an option on series 1, standard on series 2 (Don't quote me on that one!!)
Also some electrical components on engine are different, eg. coil packs
There might be more but that's what I have discovered anyway....
Hope it is of some help,
Cheers
a plastic wheel turbo? are u sure? wouldnt that...melt? hehe
..i think the ceramic turbo is stock in ALL SKYLINES series 1 & 2.
anyways, im buyin a series 2 in abt 2months, and i definately like it more than the series 1 look..plus its a newer car..if u can afford it $25-32000.
I think the plastic wheel thing is true. Must've been a cost cutting exercise, but some say it has a positive in that it spools quicker? JAGR33 covered the differences pretty well I think. As for ABS, it isn't standard in Series 2 either, in fact it's still quite rare to find ABS and sunroofs on Series 2s. My friend has a Series 2 with a sunroof (he was lucky) and no ABS. I prefer Series 2s personally, they look more modern.
Hope this helps.
Hope this helps.
it not a cost cutting thing to have a plastic turbo wheel, it spools alot quicker and it very high strenght plastic that would never melt but rather just break off if pushed 2 much!
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
