Hi Guys,
I'm looking at getting a q45afm, and were wondering if it would be too big.
I have a fmic, pfc, full exhaust, GT30 (.7ar) turbo and other systems to support.
Is there such thing as getting an AFM thats too big? I know this one is a size up from the z32, but will it work just as good? The reason I am opting for this one is its one of the only ones I can find for a good price.
Let me know what you think.
I'm only chasing 260rwkw.
Generally the best way of deciding what fueling components to use is to choose the injector/AFM that will just get you to the desired power you are after. This way you maximise the resolution in your operating range.
That said if a Q45 is the only AFM you can find at a decent price then I would just get that. I think you can change the resolution of the specified AFM within the PFC based on a percentage amount also.
do you think I'll just be able to plug and play?
My mate is a boiler maker, and he can do anything for me to make it fit.
<img src='http://members.iinet.net.au/~sennan/pod bracket.jpg' border='0' alt='user posted image'>
were you asking me or asking in general?
youll need to adapt wiring, adjust all your pluming to suit the 90mm instead of 80mm and also choose the vh41 afm in the powerfc menu. i would have your tuner check and do it to make sure it doesnt give wacko results. the power limit of the q45 has been questioned a few times, with no real proof or evidence. would be great if someone could say i have this much, here is the graph or what not. the wiring is on my site
yeah I was asking you.
Just curious if I just plug the AFM in, will I just select it in the AFM menu, and thats it, no further tuning required?
Or does the PFC need to be retuned due to the different readings from the AFM?
a little confusing...my apologies
well im not entirely sure having never done it. that being said when you choose the afm in the powerfc menu that would be the all the adjustment that would be required in theory? now that wont work in practice so im not sure, i would say get your tuner to select and then do a dyno run checking the a/fs cos it might go mega rich or lean. a guy in melb fitted one and then it was running mega rich but im not sure on the reason so its hard to say. i guess if it pops n farts a lot when you choose the afm then its mega rich
The mixtures will most probably change I'm sorry to tell you. In theory as long as the MAF calibration within the PFC is correct it should be close but it is never really the case in practise.
A little off the subject but - I had to retune a twin screw supercharged VY crewman the other day with a new VZ 90mm MAF. The car was running the standard delphi ECU. What i did was copy the MAF calibration table from a VZ into the ECU. Now you would think with all the corrections available to the ECU that this should be enough but unfortunately it still needed some tweaking. Just goes to show that theory is still a fair way off compared to practise.
Hi Guys,
A z32 will be enough to get you to the 300kw mark.
A q45 will give up 350+ but it won't be street drivable as it will have problems idling.
Just to note.
For some wierd reason the RB20 PowerFC has a different AFM calibration airflow curve to that of the RB25 PowerFC.
Looking through a few others i.e S13,S14,S15 etc they all have a different airflow curve calibration for the same AFM?!?
I don't understand why they would do such a thing. :(
Around about the 200rwkw mark you want to look at upgrading to a z32.
ive seen this on the forums heaps but i have seen 2 cars (both friends) that made 250+ rwkw with the standard afm's .
both these cars made that power safe and comfortable with no issues.
Any one else tried pushing a standard afm until they ran into trouble?
SK???
cheers ..Jim
hi bbq
can you go into more details on the idling problems? do you know any specifics about it??
cheers
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
