Hey, im reading this form at the moment and it's saying stuff like...
'to fully appreciate many different aspects of japan it is required that the working holiday applicant moves to different areas within japan at approximately 3month intervals.'
W T F
does that mean i will have to find a new apartment every 3 months? that would completely suck ass.
But then again, move to different areas within japan could mean spending a night in osaka or going on a day trip to another prefecture or something.
Anyone here on a working holiday visa that can comment on this?
I'm going to ring the consulate in the morning but i want to double check this.
https://www.sau.com.au/forums/topic/82562-working-holiday-question/
W T F
Don't get too worried... they just say that to appease the 'working holiday ethics'. Of course NO ONE moves around in 3 month intervals! It's just saying that *in the spirit* of the working holiday visa, people are 'obligated' to move around Japan and see the country, rather than get all hooked up in one city then start doing illegal stuff ie: working fulltime :rolleyes:, having sex :D, drinking too much ;), being disorderly ;)... you get the drift.
Hey mate. I am currently living in Tokyo and came here a bit over 3 months ago on a working holiday visa. Like Rezz was saying, no one actually moves around every 3 months, that is a little unrealistic. That sort of stuff is just written there really for the sake of it (to make immigation seem like they are doing a good job) and unless you did something kinda messed up over here you will be right living in the same place the whole time. With that said however, I reckon that if you got into trouble for something else over here, they would then use it to ream you up the ass even further.
My main advice for comming over here man is to make sure you have a healthy bank account before comming. I have blown well well over 10K since getting here just on living expences so just be aware of that.
As for work, if you have a university degree it will be a piece of cake. With a degree and 1-2 years of relevant experience I know of jobs that will pay anything between 60k-150k in the first year. You really just have to be very motivated and start knocking on doors as soon as you arrive. Do you have a degree? What kind of work experience backround do you have? What are your Japanese skills like?
In all honesty, if you don`t have a degree will be an uphill battle, but not impossible. It will reallly depend on your personality.
Actually getting back to the visa situation, if you get a (career type) job (which you will need a degree for) you wont even have to worry about the visa thing because most companies will be able to sponsor you anyway with a relevant working visa. That is what is happening with me anyway.
If you have any questions, don`t hesitate to PM me. Whether you are going to be able to survive here or not really will depend on you. Despite what a lot of people think it is a very tough environment here (in Tokyo) especially if you are chasing carreer goals and not just a good time.
Good Luck!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
