If anyone can help in ANY way at all on this one, please do.
Im after a RB25DET series 1 clutch slave cyl. Good, bad whatever condition. Also if anyone knows where I might be able to get a generic one new that would also be awesome, in fact probably better. Just any info. ASAP, as the tailshaft should be done by tomorrow so the slave will be all that is holding up the works.
*for anyone who asks, yes I do know I have an rb20 in my cefiro, this is for my rb25 box which is now in my cefiro.*
http://www.skylinesaustralia.com/forums/sh...=slave+cylinder
lol - let me know how you go, as I am after a new one also.
Thats for RB20 ones. If you need an RB20 one sing out man. As I dont need my rb20 one anymore, it was recoed about 5months ago too. If you want it sing out. If you also want an rb20 box for parts... :rolleyes:
Would be surprised if they didn't sell the R33 ones as well?
Aren't the R33 the same as GTR with the push type? I had a GTR/GTS4 one the other week (bolts on the bottom) and sold it - could have done a straight swap if it was :rolleyes:
Yeah, I still need a clutch fork.. do you have one?
Aren't the R33 the same as GTR with the push type? I had a GTR/GTS4 one the other week (bolts on the top and bottom) and sold it - could have done a straight swap if it was :rolleyes:
I'll ask the mechanic what I have left tomorrow. Assuming I get the car back this week Im just going to drive all weekend so no probs dropping it off or whatever.
But yeah, I shall be trying that place, hopefully the boss wont mind me dissappering for an hour or two to pick something up.
Gents,
You can purchase them directly from Nissan for about $90. I was quoted $50 for a reconditioned unit. Can't beat a new item. Nissan had it on the shelf from memory.
Hope this helps.
Ben
Daveo, how much did your new tailshaft cost?
$450+gst from memory. That is FULL new 1 peice shaft tho. They quoted $300 to shorten my orginal one, but that had something wrong with it, so we went the single peice.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
