Hey all...
Well im on the road atleast 7-8hrs a day for work
My van is pushing 280,000km's I dont think it will last anymore...
And it would be an awesome thing to do....Putting that aside from my Other Bigger Project...
What i basically want to do is run A RB26 conversion...
Would this set up work?
motor: RB26
Gearbox: 300ZX/GTS-T/ (What would work?)
Comp: Autronic/Haltec (Wouldn't u need a computer to start from scratch including wiring)
Diff/shafts etc: What would be best?
I am so keen on eventually doing this
What are your thoughts??
Any feedback at all...
https://www.sau.com.au/forums/topic/82581-rb26-in-a-van-can-it-be-done/
I have a factory built Nissan V6 auto Urvan.Comes with the VG30de engine from the Z31 300zx.
Only got 122rwhp but a stack of torque and we have all the manifolds etc for a single turbo conversion....
Cheers
Ken
PS $11K will buy it.
And many years ago when the Nissan factory Rally team was running ( George Fury and Ross Dunkerton ) they had 2 or 3 E20 vans with L28 straight sixes in running webers etc and a close ratio 5 speed box. The boys ( aka Pete Ryan and Jamie ) reckon it was a bitch to get the column shift to work with the 5 speed but it was never late to a service point :P.
Was funny hearing the vans coming, everyone thought the rally cars had arrived.
Cheers
Ken
The van is a Toyota Hiace, 91 model
It would prb last at least 350,000km;s
But it has been through alot of thrashing Over the years
Do you reckon The rb26 would fit in or would i need to use a sr20? etc
ive thinking about dropping a rb25det in my dads nissan urvan.
its a 2.4L 4cyl carb, but the wiring and other crap wont be an issue.
just the mounts, and its connectabilty to the gearbox.
maybe slap a lsd diff on it, as its got an open wheeler and loves to spin 1 wheel around the corners!!
steve
may i say i think the last thing we need is another death trap on the roads.
high centre of gravity - check
crap brakes - check
crap suspension - check
13inch steelies with worn re-treads - check
poor visability - check
RB26 powerplant - check
now to put myself and others on the road at risk... top idea.
now, if you are going to do it properly you would need to upgrade the brakes and tyres and 'try' to upgrade the suspension. it still would not be very safe with that kind of power though.
BTW nissan didn't build an F1 van. Renault did (as someone stated above). it's the Renault Espace F1 and that was more a people mover than a van. and it was f**king awesome... I have a couple of pics but i can't seem to attach atm.
Dude! No one said it was a Nissan!!! I said it was a Honda van. However with my old age my memory is not what it used to be, so I believe I got the manufacturers name mixed up.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
