R33 GTST vs XR6 Turbo
  • Replies 103
Ive got one! For about 2 more weeks :rolleyes:. I think the XR6 would get up...but as always it would depend on the driver. On the entry to a freeway once from a set of lights I was slightly in front but I had my best launch ever! and it was only to 100 maybe that extra power would start to tell once the speeds got up
Not even comparable. Straight line times the XR6 turbo would destroy a bog stock R33. There engines have so much more 1/4 mile potential as well as power is dead easy to pull out of them. As a track car it is a different story all together...
http://www.skylinesaustralia.com/forums/in...showtopic=80479
here is a link to stock vs stock 0-100km and 0-400m. Not a lot in it really at the end of the day if they are both manual the better driver will win. That said I have driven both in manual form and the Skyline to me was a much nicer car to drive. Lighter and smoother clutch and gear box. You can really fell the weight of the XR6 when cornering to.
cheers
A quote from that dude that owns the XR6T.
"Heya all i know this is an ls1 forum but a few people on here know me so i thought id let them know where im at now
Picked my car up from HPF today after having the engine rebuilt it makes 330rwkw at 3000rpm and max power 391.5rwkw with the factory turbo running out of puff looks like time for a bigger turbo
But what is impressive is the tourqe 12000N of tractive effort on the dyno which even HPF were amazed at
The car has a c9 3 speed fully manual shift auto in it now and in top gear at 100kph you can floor it and light up the tyres all you want
Hopefully is the rain holds out i will make it to calder tomorrow night now i got to get the power to the track"
330rwkw at 3000rpm.. Thats flamin awesome.
I've said before and I'll say it again..
There's no replacement for displacement. :O
Had a couple of run in's with XR6T's.. problem is they have all the power from the second they put the pedal down..
while I have to wait till 2nd gear to really start the power coming on.. my cars stock except cat back exhaust.. by which stage i'm doing 80/100 in a 60 zone.. not good..
maybe with the 8psi full time mod it'd be different.. will endevaur to g-up someone next time I see one..
:O
I would have guessed the xr6t. power to weight it has it, and then it also has a fair slog of bottom end grunt from the extra 1.5 litres or so. I still think it says a whole bunch for an up to 12 year old 2.5 litre car that it can more or less keep up with the new meat. .3 of a sec is bugger all!
:O
How do you know there cars are stock? Lots of XR's going around with just the EDIT which gives them about 20-40rwkw more.
Who would win this drag race?
Both manuals, both bone stock.
I have only race 1 XR6T and it was auto;
Background info on my skyline its r33 but has rb20 size turbo (i was making 170rwhp at the time i race the XR6T)
It was equal untill i change gear, his was auto had a smoother change and pull ahead by abit, i think stop cuz gf gave me an eye look.
So basic 0-60km it was equal with my 170rwhp
i'd say 80 - 90% of them are stock that you see on the roads..
most people wouldn't void a warranty on a new car that's already pretty quick as it is..
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
