Yeh, Akitas can be known to not only have a short attention span - but short temper, too. Meaning they can be snappy if annoyed - so definately get Obi lovin' kids and stuff and as used to as many things as possible.
They become stupidly loyal to your family though :) And lots of ppl go ohhhhhhh ahhhhh what a pretty dog!
Obi went to puppy school last wednesday. He loved it, but he got attacked by an 8 week old jack russle that would have been the size of obi's head! little turd. All the dogs there were sooo little, i thought that Obi may hurt them, but he played very well with the other dogs. The only other dog close to his size was a rotty, but it was a bit timid, obi wanted to play with him but he kept running away. Obi goes again this wednesday.
Hes putting on weight, when we weighed him at puppy school, he had put on 1.3 kgs in a week. hes about 8.3kgs at the moment i think. Little fatty! Hes prob put on more this week, hes growing fast, slowly growing in to all his skin, but hes still got an addorable double chin :P
Dog is very cute guys, nice choice
personally I've always wanted a pure bred labrador, maybe once I finished studying will get one......
Troy, please tell me you are not gonna name your kids after star wars characters, though I think the Doc's would get a kick outta putting Princess Leila on the birth certificate of your daughter :D
adrian:p
  • 4 weeks later...
for god sakes dont all three of you couples do it at the same time. I could never afford that while rebuilding the car.
hmm... formulates terrible plan to make sileighty broke.
updates lets see Obi graduated puppy school.
Obi's 15kgs at 15 weeks and about knee high already. He starting to be mischevious along with thinking hes a lapdog (Kylie spoils him)
need to take new photo
Here's a picture of my Sammy B) He's waiting for me to let him close the door for some privacy :(
Sammy is about 6 years old and 65-70lbs, he was the runt of the little so he's on the smaller side of his brother's and sister's
Akitas have the highest biting pressure out of any dog breed. Pit bulls are second in this category at an average bite pressure of 900psi. Akita's have been known to have as high as 2300psi bite pressure when fully grown. Very protective breed. Originally bred as a fighting dog. shares more genes with wild bears than any other breed. But if u raise them right it doesnt matter about the breed. Ive got a rotti cross shar pei and she is like a teddy bear around people. Will run around and play with all dogs but yet still fearless against next door's pitt bull (i mean mastiff cross as it says on the books).
nice husky... I like them too...
Ok... update.. oby is 17 weeks old and weighs prob just over 20kgs... still thinks hes a lap dog :) and no... I DONT SPOIL him... when troy tells him off he doesnt scare the dog at all... obi goes quivering when i say no!
Anyway... As soon as i get the opportunity to load pics from my phone etc.. ill put some more up. He hasnt changed much, apart from the size. Hes nick name is bear btw... should see the size of hes paws!!!!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
