Hey ppls.
I bought this turbo about three months ago in the expectation that I would high flow it at GCG.
I since discovered the wonderful VG30DET hybrid turbo mod, and i have aquired a hybrid ready to high flowing, hence, i don't need the R34 GTT turbo now.
The exhaust wheel has several small chips, but the bearing pack is good.
Really only suited to a High Flow. Comes as shown in pics (which will be posted in about 1 hour.
Price is what I paid for it which is $250. FIRM Don't ask to bargain.
Price is $250.
I can send anywhere via TNT (small additional charge) or you can pick up in Melbourne.
BASS OUT
  Bass Junky said:
Hey ppls.
Price is $250.
BASS OUT
Anyone who is thinking about highflowing their R33 turbo should buy this one and sell your working stocker because the R34 turbo has a larger exhaust turbine housing and will give more power than an R33 one.
Here are the pics.
You can see that the exhaust wheel is chipped. Nobody can figure out why it's chipped and not completely knackered.
Anyway, it still spins fine and the is no shaft play.
Thank's but I'll have to give it a miss... I was just quoted by GCG to hi flow this unit, and at their price, I'd rather get a brand new GT-RS for not much more.
Good luck with the sale...
hey iv got an r33 rb25det and im looking to hi flow my turbo but wanted to have the vg30 exhaust housing fitted to it also (similiar to bullant47s set up). can this be done with your r34 turbo? how much more power do you get out of the r34 turbo in comparison to the r33? do i even need the vg30? or is the vg30 it still worth doing?
VG30 is super hard to find at a price that is reasonable.
The turbo will bolt straight up to an R33.
It would be handy to have the turbo to high flow while you are still running your existing turbo. Saves having your car off the road. Then you can sell your current turbo.
Exactly what I'll be doing with my hybrid.
BASS OUT
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
