Year: 1997
Model: R33 GTS-t
KMs: 32,000 (aftermarket speedo) - Only 3,000km have been done in this country!!
Colour: White
Transmission: Manual
Mods:
HKS GT2835 Pro S (integral wastegate) 0.64 exhaust housing
HKS Stainless Steel Tubular Manifold
HKS Intercooler
3" HKS Exhaust (Turbo back)
Greddy Inlet Manifold
Nismo Adjustable Fuel Pressure Reg.
HKS 550cc injectors
HKS Air Filter
Apexi coolant surge tank
Custom Aftermarket alloy radiator
HKS oil cooler and oil filter re-locator
Tomei 270 degree cams with 10.25 mm lift (biggest you can get for an rb25 unless you custom make some)
Tomei Solid Lifters
Tomei Valve Springs
Tomei Adjustable cam gears
Cusco Oil catch can
Upgraded Nismo Fuel pump
HKS F Con V pro (AFM less), a Power FC is supplied so it can be tuned.
Blitz Type R Electronic Boost Controller
Tomei 2 way LSD
OS Giken Twin plate clutch
Nismo Slave cylinder
Tein HA height adjustable coil overs Shocks
Tein Adjustable Caster Rods
Cusco Adjustable front strut brace
Cusco Solid Rear strut brace
Cusco Master Cylinder brace
Nismo Front sway bar
Nismo rear sway bar
Enkei RS evolution wheels (approx 3000km on the tyres)
Greddy Pillar Pod
Apexi mechanical boost gauge
HKS Oil temp gauge
HKS Water temp gauge
Greddy Exhaust temp gauge
Momo Steering wheel
Factory ABS
EDIT: More Pictures Added and more mods added.
Edited by ookami
na sorry, too much work involved in returning it to stock, the head has solid lifters and has been modified to take the bigger cams, so i would need another head.
And it would probably make me cry .... its an awesome car.
  • 4 weeks later...
Are u interested in sputting it back to stock and selling the parts?..
U might get more over all..
Shot gun for the turbo.... :D
Always cracks me up when i hear these kinda responses. No offence meant, but why would he spend so much time and money on it to pull it apart again and sell it off. Would cost more than he'd make.
Good luck with it dude, neat car. :O
  • 2 months later...
Bump - come on, is a really awesome street car and much higher power skylines can't keep up on the street including gtrs (except from a launch of course :) )....
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
