Year: 1997
Model: R33 GTS-t
KMs: 32,000 (aftermarket speedo) - Only 3,000km have been done in this country!!
Colour: White
Transmission: Manual
Mods:
HKS GT2835 Pro S (integral wastegate) 0.64 exhaust housing
HKS Stainless Steel Tubular Manifold
HKS Intercooler
3" HKS Exhaust (Turbo back)
Greddy Inlet Manifold
Nismo Adjustable Fuel Pressure Reg.
HKS 550cc injectors
HKS Air Filter
Apexi coolant surge tank
Custom Aftermarket alloy radiator
HKS oil cooler and oil filter re-locator
Tomei 270 degree cams with 10.25 mm lift (biggest you can get for an rb25 unless you custom make some)
Tomei Solid Lifters
Tomei Valve Springs
Tomei Adjustable cam gears
Cusco Oil catch can
Upgraded Nismo Fuel pump
HKS F Con V pro (AFM less), a Power FC is supplied so it can be tuned.
Blitz Type R Electronic Boost Controller
Tomei 2 way LSD
OS Giken Twin plate clutch
Nismo Slave cylinder
Tein HA height adjustable coil overs Shocks
Tein Adjustable Caster Rods
Cusco Adjustable front strut brace
Cusco Solid Rear strut brace
Cusco Master Cylinder brace
Nismo Front sway bar
Nismo rear sway bar
Enkei RS evolution wheels (approx 3000km on the tyres)
Greddy Pillar Pod
Apexi mechanical boost gauge
HKS Oil temp gauge
HKS Water temp gauge
Greddy Exhaust temp gauge
Momo Steering wheel
Factory ABS
EDIT: More Pictures Added and more mods added.
Edited by ookami
na sorry, too much work involved in returning it to stock, the head has solid lifters and has been modified to take the bigger cams, so i would need another head.
And it would probably make me cry .... its an awesome car.
  • 4 weeks later...
Are u interested in sputting it back to stock and selling the parts?..
U might get more over all..
Shot gun for the turbo.... :D
Always cracks me up when i hear these kinda responses. No offence meant, but why would he spend so much time and money on it to pull it apart again and sell it off. Would cost more than he'd make.
Good luck with it dude, neat car. :O
  • 2 months later...
Bump - come on, is a really awesome street car and much higher power skylines can't keep up on the street including gtrs (except from a launch of course :) )....
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
