Sau Track Day Wakefield Park September 11
Abo Bob
 Share
In association with RENEW, the Rotary guys, we are having another track day at Wakefield Park on Sunday September 11.
Cost is $130 for members and $160 for non members.
You must get your form and payment in to secure a spot and since RENEW have the jump on us they already have a number of spots taken so you better get in fairly quickly in order to secure a position.
Entry Form
In order to simplify things this time the form goes straight to RENEW if posting, details are on it, however you can still fax the form to us on 9237 0814.
UPDATE
There are only 3 spots left so people need to get their money and forms in ASAP.
  • Replies 153
Interested.
I've never been to a track day before, so would be keen to give it a go. Just need to sort a few things out first before deciding to commit to the day.
Just curious, will there be any instructors available on the day?
I wouldn't mind getting some pointers on braking points, driving lines etc as I know I could probably do with some guidance being first time out and all...
John - You've seen it now and there are spots now so that will do. :O Rx7s go pretty quick around a track.
Brendan there will be instructors on the day. There will also be people like me and Duncan and other SAUers who have been to many track days and would be happy to go out with you and show you around.
In fact, the first session is devoted to exactly that. Have a read of the form I've linked to in my signature.
This time you can bring as many people as you like but there is no second driver unless you pay a second fee.
The other thing to take note of for those with no track experience is that Wakefield Park is as safe a track as you will find. The runoff areas are large and flat, the only wall is along the straight so you can't hit that and it would take a pretty serious car to hit 200km/h on it meaning that it takes skill rather than outright power to do well.
Basically it's the best track to learn on and still fun for those with experience.
NO I CANT IVE ALREADY REACHED MY DAILY LIMIT IVE BEEN BUYING GOODIES FOR MY CAR SO I HAVE TO WAIT TILL TOMORROW,DO YOU WANT ME TO RE FAX IT TO YOU TOMORROW WHEN I HAVE A RECEIPT NUMBER?
 Share
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
    • I have heard the frenchys kit (with the smaller toyota compressor) performs fantastic. i havent actually gassed my system yet, so cant confirm myself..
    • https://www.efisolutions.com.au/injector-lower-manifold-collars-adapters-r33-a32-y?gad_source=1&gclid=EAIaIQobChMIjpXb2aLaiAMVYcA8Ah1zkg6JEAQYASABEgJzG_D_BwE
    • correct Ive moved to a r33 oem ball joint - they are actually thicker than alot of the after market and similar
