Well I put in my new ground cable. It's bigger than the old but I can't take a picture because the digicam is out and about somewhere.
Coincidentally my car now has a crazy bad idle - drops to 800rpm from 1000rpm, when my fan goes on, when I use my power window my lights dim. I think it's unrelated (I suspect my head gasket gone).
Ahh always something :\
re Alternators:
from memory:
if the volts in battery drops then the alternator ups the volts to get battery upto right level i.e. should be charging between 13- 14.4V, if current isnt amps aren't right then it drops the volts and puts more amps into the battery. i.e. you can have a battery showing 12v but it has no guts as it can't put out the amps.
This probably explains why the alternator is putting out 14~v when car is cold, because the battery has just been drained from starting the car, and because cold temps load the battery more.
  • 4 weeks later...
Erm. Why do you need a group buy? Go down to Jaycar and buy 8G or 4G power cable and away you go?!
Either that, or buy an HKS/NISMO/RICER ground kit and waste your money and prove you're just a consumer whore?
:P
Edited by MarkE
Does anyone know exactly where the earths are on an R32 GTR? I know there's battery / chassis and engine / chassis but I think there are other major ones also.
The other 2 main ones I can think of are from the chasis to front and rear subframes. But the main one like you said is battery, chassis, block/engine mount
Even Jaycar's cable is a bit exy, when i was living in Melb i went to a cabling specialist (in Moorabin), paid about half what Jaycar wanted for 4G stuff.
Cigweld has amazing quality welders lead for cheaper then Jaycar also. Its very soft and flexable, heaps of sizes. Dont go in asking for X guage, say what you want in mm^2, we arent american.
Yeah Jaycar cable is very expensive. Their margins are very high. If you complain and tell them that, and ask them to do a better price, I've found they will. Hornsby and St Leonards stores have always treated me well.
  • 4 weeks later...
Hey all, now that these earthing kits are now $50 delivered, (including 5 cables) do they represent good value?
My idle seems to drop a fair bit when i turn the lights on and when winding windows up and down, if i can get all the bits and pieces i need for $50 at my door, ill do something about it.
Otherwise i'll just live with it! (as im really slack eg. had my Jaycar IEBC and DFA kits completed for 4 months and still havent put them in my car. Probably could have paid for them over with the fuel i would have saved.)
  • 1 year later...
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
