Well I put in my new ground cable. It's bigger than the old but I can't take a picture because the digicam is out and about somewhere.
Coincidentally my car now has a crazy bad idle - drops to 800rpm from 1000rpm, when my fan goes on, when I use my power window my lights dim. I think it's unrelated (I suspect my head gasket gone).
Ahh always something :\
re Alternators:
from memory:
if the volts in battery drops then the alternator ups the volts to get battery upto right level i.e. should be charging between 13- 14.4V, if current isnt amps aren't right then it drops the volts and puts more amps into the battery. i.e. you can have a battery showing 12v but it has no guts as it can't put out the amps.
This probably explains why the alternator is putting out 14~v when car is cold, because the battery has just been drained from starting the car, and because cold temps load the battery more.
  • 4 weeks later...
Erm. Why do you need a group buy? Go down to Jaycar and buy 8G or 4G power cable and away you go?!
Either that, or buy an HKS/NISMO/RICER ground kit and waste your money and prove you're just a consumer whore?
:P
Edited by MarkE
Does anyone know exactly where the earths are on an R32 GTR? I know there's battery / chassis and engine / chassis but I think there are other major ones also.
The other 2 main ones I can think of are from the chasis to front and rear subframes. But the main one like you said is battery, chassis, block/engine mount
Even Jaycar's cable is a bit exy, when i was living in Melb i went to a cabling specialist (in Moorabin), paid about half what Jaycar wanted for 4G stuff.
Cigweld has amazing quality welders lead for cheaper then Jaycar also. Its very soft and flexable, heaps of sizes. Dont go in asking for X guage, say what you want in mm^2, we arent american.
Yeah Jaycar cable is very expensive. Their margins are very high. If you complain and tell them that, and ask them to do a better price, I've found they will. Hornsby and St Leonards stores have always treated me well.
  • 4 weeks later...
Hey all, now that these earthing kits are now $50 delivered, (including 5 cables) do they represent good value?
My idle seems to drop a fair bit when i turn the lights on and when winding windows up and down, if i can get all the bits and pieces i need for $50 at my door, ill do something about it.
Otherwise i'll just live with it! (as im really slack eg. had my Jaycar IEBC and DFA kits completed for 4 months and still havent put them in my car. Probably could have paid for them over with the fuel i would have saved.)
  • 1 year later...
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
