I don't seem to have the function that allows me to edit the RB25DE (someone musta swapt my VG for an RB whilst i was asleep last night) thingy underneath my avatar. i've looked in "my controls", "profile info" as directed by other in the forum but it seems i don't have the "custom title" option that is meant to be there....
I also seem to get a run time bug everytime I open a page, although it still opens without problem... something about an Undetermined string constant. the only really enoying thing is that i get prompted every single time i open a post. here is a pic of the error...
Oh yeah and does anyone know if the gallery will be linked to peoples stats on the side bar? that was pretty cool before.
I do prefer the old forum, but i think this one is fine as well. just need to iron out the bugs....
good job guys B)
https://www.sau.com.au/forums/topic/82688-a-few-minor-problems-errors/
use firefox :O
at home might be fine other than the fact that i dont particulary like firefox, but i do most of my browsing at work and they have managed to block almost (i do say almost cause i have found gaps) all modifications to the systems they run....
anyhow the forum shouldn't (nor do i think it is) be designed to only run properly on one type of browser....it still dos'nt really fix the other problems i'm experiancing such as the missing functions....
no your right :rolleyes: It should work in any browser, even ie.
Just tried IE, and yeah i get the same error, but i have disabled the script alert stuff so its just a little yellow icon down the bottom left corner. Go through your ie settings - >advanced disable script debugging. If you needed it you'd know about it.
I want my turbo back :)
i want my VG back :lol:
thanks ferni, i'll check that out at work. my pc at home has none of these problems, but i'll fiddle around with the work pc....
thanks for all the hard work on the forum Prank... it's coming together nicely, I miss the old style, but once the few little things get ironed out it'll be as good as ever.
cheers
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
