Hi, Time for change.
HKS T04S Turbocharger up for grabs..
Details :
Super Response Turbo FOR RB25/30 with a shitload of power!
550PS TurboCharger..... Good for 400RWKW+ with minimal lag.
Freind currently pushing 355rwkw on a T04S with the smaller .84 exhaust housing
This the 1.00A/R V-band exhaust housing.
Genuine HKS. Can supply oil line braided HKS for extra $100.
Also have a wastegete for this,high boost application 35mm GT1 wastegete.
base spring is 12psi, can go upto 1.5bar with boost controller.
Also HKS EVC4 dual solenoid with warning overboost feature etc....
Postage & Handling is $30 For Turbo, $15 for Gate, $12 EVC
good boost controller
wastegate - $400
evc 4 - $350
turbo - $1200
https://www.sau.com.au/forums/topic/82705-hks-parts-turbogateevc/
Details :
wastegate - $400
evc 4 - $350
turbo - $1200
whould be interested can you bolt it stright on or do you have to get a manafold is the evc4 a digital boost controler am very keen to get this where abouts do you live and how long whould it take to get as i whould like to get them asap
Hi,
It can be made bolt on, my freind put T04E on his car (r33) it was bolt on, he just had to get dump pipe and t3/t4 flange made up. I can get contacts for you if you want.. but, yes it can be done "bolt on"
EVC4 = Electronic Valve Controller version 4 :)
Yes it is electronic dual solenoid :)
do a deal for the lot very keen to buy just got my tax back where abouts do you live as im in brisbane pm me if you want to do a deal
i PM'd you
this turbo is wonderfull for a 2.5L better for 2.6L and Exccellent for 3.0L conversion
400+KW Garunteed or else money back ( you must have fuel system and ecu to match with engine)
turbo is like new , no oil leak into intercooler piping! like new!
price drop 1100
evc4 350
wastegate 355
oil line 85
vband clamp 50
  • 1 month later...
Hey mate ur inbox is full so here is my pm haha
Hey mate if u still haveur boost controllewr avaible ill givbe u 250$ cash straight up for it! As long as it in perfect working condition!
If u accept plz pm me back with ur bank details and ill get cash in there straiught away!
Details :
wastegate - $400
evc 4 - $350
turbo - $1200
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
