:rolleyes: heya
as posted by the man - bigdatto in his other thread (trick out ps2 for $0)
The good people at AusDigital have released an all-in-one GUI based Exploit disc compiler to make life VERY easy for everyone. details at http://www.ausdigital.net/
All you need now is a PSX disc, PC, CD burner, PS2 & memcard, net adaptor & IDE HDD. Brain no longer required.
well....I'M BLODDY LOST
i have the above things (ps2, ps1 game, PC, burner, ps2 + memcard, official network adaptor thing and a hard drive hooked up.)
but i dont know what to do next. i want to be able to copy things (games/movies to the hard drive as the laser is getting crappy.
i've been trying everything, searching all over the web but still nothing
please help me.
the closest i've come is finding places that want to sell me some cd magic thing that comes with a slide tool or "hdloader" as i have read about here and other places lots, that allows you to do the swap but i figured that was before my "brain was no longer required"
sorry to look like a noob ;)
help
Jimbo tried PMing you but bounced back ? email please ?
msg is :This message can not be sent because the recipient does not have permission to use the personal messenger or their personal messenger inbox is full.
This personal message has not been sent
Alright, i'm at this point and i need further assistance...
I have been following the instructions at lookatthemonkeys.com:
1. I ran titleman.exe using the SCES info on my PS1 disc.
2. I ran CDGenPS2.exe and made an ISO of the required files.
3. I burned the ISO generated onto a CD.
4. I have 2.5MB free on my memory card.
5. I insert the SwapMagic CD and wait for the main screen.
6. I use the slide tool to open the PS2 CD drive.
7. I place in the burned CD.
8. I close the PS2 CD drive & use the slide tool to lock it in place.
9. I press "X" on the controller and I get a blank screen that never does anything.
I assume this final stage is where it is meant to copy the required files onto the memory card so that if the PS1 game is in the drive it will load .ELF files off the Memory Card.
If I put the .ELF file onto a USB memory stick and have that in the PS2 USB port while Swap Magic is loading up it will automatically load the .ELF file on the USB memory stick, but then it has problems with CDVD.IRX. I assume they need to be on CD or it won't work.
i am using swap magic 3.6
anyway, yeah
help
cheers dudes
jimbo
Sounds like you're doing everything right. Did you place a dummy file (50-100meg) in the disc image ? Ps2 might not be able to read the disc if the image is too small. I've experienced problems with some media also. $ony CDR's just won't read at all, surprise surprise.
I still advise you to get the Ausdigital compiler. It works faultlessly every time.
Patience will reward you, Jedi.
hey matey, sorry for not replying sooner
been working like an absolute bitch
yeah a mate of mine got it figured out and has been working on it over the last few nights but i havnt been here to enjoy it yet
i was able to play san andreas aithout the disc in tho :D
success
thanks for all the help mate
Jimbo
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
