Originally posted by MrMayhem
is there a contest on at the momment to see whos got the biggest number of posts or something?
hahah if you thinking I am wasting forum space... fair enough, but it's not my intension.
I was simply asking is it good thing if you dont see the oil drops under the drive way...
only asking because all the cars I've seen had oil marks time to time... but I never seen on my car... it's clean as...
I would thought it' bad thing...
cheers
Joe
My Gearbox has a slight seep from the front oil seal.
The front seal from nissan is $5 so i have to get around to replacing it. BUT with my Input shaft bearing noise I am trying to hang off as long as possible hoping that it will go before the seal does.
Originally posted by 2fardown
No this is bad....your engine should leak at least 2 litres of oil a week.  You might want to get it checked out.
No hes serious Joe!
I lose about a litre a week..
Apparently a screwdriver and a hammer will get it back to 2 litres.
You the sphincter of the universe!
  • 1 month later...
hey guys ive come to the realisation that the reason u dont see minor oil drips is because the plastic underlay under the engine actually catchs the drippin oil......thats why u dont see any on the ground hehe:D im abit worried cause i had a look at that underlay the other day and saw some spots where oil has been drippin on it. so the question here is whats the possible cause of the oil leak??
thanks
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
    • Well found out it’s a 60th anniversary gtst from that it came with 205-55r15
