hi everyone,
Just got a new set of work wheels with supposedly correct offset for a 34GTT. The wheel in question are the fronts (18x8 +35). Had brake caliper clearance issues (standard nissan calipers) and have put 5mm spacers in the front. They have now cleared the calipers but only by a hairs length! I shit you not when I say a hairs length! Wheel shop told me if they did not hit in the first place they will never do. but today under slight heavy breaking it scraped ever so slightly. I'm thinking 10mm bolt on hub adaptors...are these legal and how hard is it to find a 10mm one? Any input would be much appreciated.
Cheers
https://www.sau.com.au/forums/topic/82734-bolt-on-hub-adaptors/
hi everyone,
Cheers
I thought an offset of +35 should be alright for gtst? Hmm... maybe it's the design of the wheel. I had the same issues when i bought my wheels, with offset +38. Had to use bolt on wheel adaptors as wheel spacers are too dangerous. I think you can probably buy them from some tyre stores. Give me a PM if you can't find any, I'll put you in touch with the place where I bought them from. :rolleyes:
Thanks zigenGT,
yes +35 on an 8inch wide wheels would normally be correct but because of the design of these spokes they hit the calipers. Yes I know spacers are not legal, they were more a quick fix to get the car on the road, hence my question on bolt on hub adaptors...are they legal? Zigengt, what size adaptors did you use n how much did they cost?
Thanks again for the replys.
Thanks zigenGT,
I bought 25mm bolt on adaptors :rolleyes: They cost $80 each fitted. Have driven 7 months no problems at all.
What car u driving? I'm thinking 25mm may be too much for a 34GTT....do 10mm ones exist? fitting a 25mm hub adaptor would make an existing wheel with +35 become +10??? Someone correct me if i'm wrong...
You cannot get 10mm bolt-on's because it needs to be wide enough to allow for the extra bolts.
PM me if you are after some spacers, I can get 20mm, 25mm or 30mm they are $85 each
Merlin,are u refering bolt on adaptors tht you can get or spacers? Want to stay away from spacers if i can. The 5mm ones only cost me $10 each....
My offset is +38. I was concerned the wheels might look too wide but the flush along the guards :)
Do the calipers have NISSAN cast on the top, if so file the letters off and that will gain you a couple of mil extra clearance.
hehe, I was running a set of rims on the rearonce, which were so close it shaved the paint off the "NISSAN" letters!!!!!
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
