where the fu*k do ppl practise drift in bris? out here at wynnum, theres an ok industrial estate with nice wide streets, only problem is square gutters, and lots of em!!!! so come on, tell us where do u perfect the art of DORIFTO
we need some dedicated drift tracks, where u can circulate under 80km/h and still be going hard... ebisu drift course!!!!
https://www.sau.com.au/forums/topic/8277-drifting-in-bris/
try belbowrie out near indooroopilly really surburban and quiet during the day (unless you have skylines roaring down the streets) been there a few times real country no live stock on the roads there all fenced in and not many police at all. kids well its too hot there most of the time to go out on the streets and its farming country and flat so you would see them. nice bending roads and some really good spots
https://www.sau.com.au/forums/topic/8277-drifting-in-bris/#findComment-119661
Guys, this is a public forum. We should neither discuss proposed illegal road drifting venues or be seen to encourage it. 1. If you do, people will know where you will be and what you'll be doing. 2. Bad image for the club.
I have organised 2, and attended 3 skidpan days in the past with this and another club. I am currently talking with the guys who run these events about doing another one and moving to another venue as well, so sit tight, there will be mad legal safe drifting soon.
https://www.sau.com.au/forums/topic/8277-drifting-in-bris/#findComment-120173
Wecker Rd, Mansfield has a nice industrial estate. I just said that because I am supporting local bussiness, they have tire, hardware and wreckers along there. DO NOT DRIFT THERE IT IS A BAD THING but on a side note theres some nice wide roads with 45 degree gutters (the "good" ones) and its away from houses. Again, good local bussinesses that should be supported and drifting is BAD BAD BAD.
Another side note, thats where I blew the diff in my kingswood. I was doing a simple u-turn. Thats all I swear.
https://www.sau.com.au/forums/topic/8277-drifting-in-bris/#findComment-123628
Guest Boxhead
moderators, i think that there not discussing illegal drifting, there discussion the best place to drift, in which case im sure they would be consulting there local council on holding some sort of drift event legalised similar to the street sprints in events section...with closed of roads etc
https://www.sau.com.au/forums/topic/8277-drifting-in-bris/#findComment-124635
I have been to a few nite events held by SR20 club...its all the way out @ Queensland raceway(willowbank complex) but it doesnt seem to bad an event..$70 once u a member and u can get them to supply some snow tyres fitted up for the hell of not costing you rubber...
VERY, VERY interested if some people can get together to find a good venue closer to bris...
Other then that, the local business @ Brendale isn't doing to bad either.............wink,wink!!
https://www.sau.com.au/forums/topic/8277-drifting-in-bris/#findComment-140419
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
